Google Stadia Controller Battery Replacement
Выберете то, что вам нужно
  1. Google Stadia Controller Battery Replacement, Loosen the screw cover adhesive: шаг 1, изображение 1 из 1
    • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Google Stadia Controller Battery Replacement, Insert an opening pick: шаг 2, изображение 1 из 2 Google Stadia Controller Battery Replacement, Insert an opening pick: шаг 2, изображение 2 из 2
    • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
  3. Google Stadia Controller Battery Replacement, Remove the screw cover: шаг 3, изображение 1 из 3 Google Stadia Controller Battery Replacement, Remove the screw cover: шаг 3, изображение 2 из 3 Google Stadia Controller Battery Replacement, Remove the screw cover: шаг 3, изображение 3 из 3
    • Slide the opening pick along the screw cover to slice the adhesive.
    • Use a pair of tweezers or your fingers to remove the screw cover.
    • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
  4. Google Stadia Controller Battery Replacement, Unfasten the rear case screw: шаг 4, изображение 1 из 1
    • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
  5. Google Stadia Controller Battery Replacement, Disassembly information: шаг 5, изображение 1 из 2 Google Stadia Controller Battery Replacement, Disassembly information: шаг 5, изображение 2 из 2
    • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
    • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
  6. Google Stadia Controller Battery Replacement, Pry open the stadia controller: шаг 6, изображение 1 из 3 Google Stadia Controller Battery Replacement, Pry open the stadia controller: шаг 6, изображение 2 из 3 Google Stadia Controller Battery Replacement, Pry open the stadia controller: шаг 6, изображение 3 из 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
    • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
    • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
    • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
  7. Google Stadia Controller Battery Replacement, Insert an opening pick: шаг 7, изображение 1 из 2 Google Stadia Controller Battery Replacement, Insert an opening pick: шаг 7, изображение 2 из 2
    • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
  8. Google Stadia Controller Battery Replacement, Pry open the Stadia controller: шаг 8, изображение 1 из 3 Google Stadia Controller Battery Replacement, Pry open the Stadia controller: шаг 8, изображение 2 из 3 Google Stadia Controller Battery Replacement, Pry open the Stadia controller: шаг 8, изображение 3 из 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
  9. Google Stadia Controller Battery Replacement: шаг 9, изображение 1 из 3 Google Stadia Controller Battery Replacement: шаг 9, изображение 2 из 3 Google Stadia Controller Battery Replacement: шаг 9, изображение 3 из 3
    • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
    • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
  10. Google Stadia Controller Battery Replacement: шаг 10, изображение 1 из 3 Google Stadia Controller Battery Replacement: шаг 10, изображение 2 из 3 Google Stadia Controller Battery Replacement: шаг 10, изображение 3 из 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
  11. Google Stadia Controller Battery Replacement: шаг 11, изображение 1 из 2 Google Stadia Controller Battery Replacement: шаг 11, изображение 2 из 2
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
    • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
  12. Google Stadia Controller Battery Replacement: шаг 12, изображение 1 из 3 Google Stadia Controller Battery Replacement: шаг 12, изображение 2 из 3 Google Stadia Controller Battery Replacement: шаг 12, изображение 3 из 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
    • Repeat the previous procedure at the clamp left to the headphone jack.
    • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
  13. Google Stadia Controller Battery Replacement, Unfold the front cover assembly: шаг 13, изображение 1 из 3 Google Stadia Controller Battery Replacement, Unfold the front cover assembly: шаг 13, изображение 2 из 3 Google Stadia Controller Battery Replacement, Unfold the front cover assembly: шаг 13, изображение 3 из 3
    • Avoid straining the front cover assembly cable during this step.
    • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
  14. Google Stadia Controller Battery Replacement, Remove the adhesive tape: шаг 14, изображение 1 из 2 Google Stadia Controller Battery Replacement, Remove the adhesive tape: шаг 14, изображение 2 из 2
    • Use a pair of tweezers to peel the clear protective tape off the ZIF connector on the left side of the rear case.
  15. Google Stadia Controller Battery Replacement, Open the ZIF connector: шаг 15, изображение 1 из 2 Google Stadia Controller Battery Replacement, Open the ZIF connector: шаг 15, изображение 2 из 2
    • Use the pointed end of a spudger to open the ZIF connector holding the button contact board cable in place.
  16. Google Stadia Controller Battery Replacement, Disconnect the flex cable: шаг 16, изображение 1 из 3 Google Stadia Controller Battery Replacement, Disconnect the flex cable: шаг 16, изображение 2 из 3 Google Stadia Controller Battery Replacement, Disconnect the flex cable: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to carefully disconnect the flex cable of the button unit by pulling it out of the ZIF connector in a flat angle.
    • Separate the front from the rear assembly.
    • Remove the thumbsticks by pulling them straight upwards for an easier handling in case you want to do further disassembly.
  17. Google Stadia Controller Battery Replacement, Unfasten the screws: шаг 17, изображение 1 из 1
    • Use a Torx T8 screwdriver to remove the seven 9.6 mm-long screws securing the motherboard assembly.
  18. Google Stadia Controller Battery Replacement, Pry up the motherboard assembly: шаг 18, изображение 1 из 2 Google Stadia Controller Battery Replacement, Pry up the motherboard assembly: шаг 18, изображение 2 из 2
    • The motherboard assembly is held in place at four points in the controller's rear cover.
    • Make sure to use the long and not the curved edge of the Jimmy during the following prying procedure.
    • Insert a Jimmy next to the right shoulder button and black plastic clamp of the motherboard assembly.
    • Align the long edge of the Jimmy with the corner of the black plastic clamp.
    • Pry up the motherboard assembly by tilting the Jimmy downwards to open the plastic clamp.
  19. Google Stadia Controller Battery Replacement: шаг 19, изображение 1 из 2 Google Stadia Controller Battery Replacement: шаг 19, изображение 2 из 2
    • Insert a Jimmy next to the left shoulder button and black plastic clamp of the motherboard assembly.
  20. Google Stadia Controller Battery Replacement: шаг 20, изображение 1 из 3 Google Stadia Controller Battery Replacement: шаг 20, изображение 2 из 3 Google Stadia Controller Battery Replacement: шаг 20, изображение 3 из 3
    • Insert a Jimmy at the top edge of the Google Stadia controller just above the charging port.
    • Pry up the top edge of the motherboard assembly by tilting the Jimmy downwards.
    • The charging port is clamped into an opening in the rear cover of the stadia controller. Make sure the charging port is not stuck in its recess during the prying procedure.
    • During reassembly make sure the charging port snaps back into its recess.
  21. Google Stadia Controller Battery Replacement, Insert an opening pick: шаг 21, изображение 1 из 2 Google Stadia Controller Battery Replacement, Insert an opening pick: шаг 21, изображение 2 из 2
    • Insert an opening pick at the top edge of the Stadia controller to prevent the charging port from snapping back into place.
  22. Google Stadia Controller Battery Replacement, Warning: шаг 22, изображение 1 из 2 Google Stadia Controller Battery Replacement, Warning: шаг 22, изображение 2 из 2
    • In the following step you'll free the headphone jack from its recess in the controller housing:
    • Avoid prying onto the black plastic cover during the following procedure.
    • Pry at the edge of the motherboard instead.
  23. Google Stadia Controller Battery Replacement, Insert a Jimmy: шаг 23, изображение 1 из 2 Google Stadia Controller Battery Replacement, Insert a Jimmy: шаг 23, изображение 2 из 2
    • Insert a Jimmy into the gap between the rear cover and the motherboard left of the headphone jack.
  24. Google Stadia Controller Battery Replacement, Pry up the motherboard assembly: шаг 24, изображение 1 из 2 Google Stadia Controller Battery Replacement, Pry up the motherboard assembly: шаг 24, изображение 2 из 2
    • Pry up the motherboard assembly by tilting the Jimmy downwards.
    • The headphone jack is clamped into an opening in the rear cover of the controller. Make sure the headphone jack is not stuck in its recess during the prying procedure.
    • During reassembly make sure the headphone jack snaps back into its recess.
    • Do not try to remove the motherboard assembly all the way yet. It is still connected to the rear cover by the battery cable.
  25. Google Stadia Controller Battery Replacement, Lift the motherboard assembly: шаг 25, изображение 1 из 2 Google Stadia Controller Battery Replacement, Lift the motherboard assembly: шаг 25, изображение 2 из 2
    • Carefully lift the left edge of the motherboard assembly in order to access the battery connector.
  26. Google Stadia Controller Battery Replacement, Separate the motherboard assembly: шаг 26, изображение 1 из 3 Google Stadia Controller Battery Replacement, Separate the motherboard assembly: шаг 26, изображение 2 из 3 Google Stadia Controller Battery Replacement, Separate the motherboard assembly: шаг 26, изображение 3 из 3
    • Use a pair of tweezers to disconnect the battery cable from the motherboard.
    • Separate the rear cover from the motherboard assembly.
  27. Google Stadia Controller Battery Replacement, Unfasten the screws: шаг 27, изображение 1 из 1
    • Use a Torx T6 screwdriver to remove the two 6.1 mm-long screws securing the battery.
  28. Google Stadia Controller Battery Replacement, Cut the battery cable adhesive: шаг 28, изображение 1 из 3 Google Stadia Controller Battery Replacement, Cut the battery cable adhesive: шаг 28, изображение 2 из 3 Google Stadia Controller Battery Replacement, Cut the battery cable adhesive: шаг 28, изображение 3 из 3
    • Use a flush cutter to carefully cut the adhesive holding the battery cable in place.
  29. Google Stadia Controller Battery Replacement, Remove the battery: шаг 29, изображение 1 из 2 Google Stadia Controller Battery Replacement, Remove the battery: шаг 29, изображение 2 из 2
    • Remove the battery.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
3 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
191 736 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
140 членов
Автор 15 207 руководств
Один комментарий
cool instruction, I just couldn't find battery replacement type.
Can you provide what's recommended as a replacement?
Wlodek Borkowski - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 31
За последние 30 дней: 108
За всё время: 3,512
