HP EliteBook x360 830 G6 Back Cover Replacement
Выберете то, что вам нужно
  1. HP EliteBook x360 830 G6 Back Cover Replacement, Unfasten the back cover: шаг 1, изображение 1 из 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Back Cover Replacement, Release the clips: шаг 2, изображение 1 из 2 HP EliteBook x360 830 G6 Back Cover Replacement, Release the clips: шаг 2, изображение 2 из 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Back Cover Replacement, Release the remaining clips: шаг 3, изображение 1 из 2 HP EliteBook x360 830 G6 Back Cover Replacement, Release the remaining clips: шаг 3, изображение 2 из 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: шаг 4, изображение 1 из 3 HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: шаг 4, изображение 2 из 3 HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
Участник с: 09/19/22
66 989 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 298 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 714
