HP EliteBook x360 830 G6 Wi-Fi Card Replacement
Выберете то, что вам нужно
  1. HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Unfasten the back cover: шаг 1, изображение 1 из 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Release the clips: шаг 2, изображение 1 из 2 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Release the clips: шаг 2, изображение 2 из 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Release the remaining clips: шаг 3, изображение 1 из 2 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Release the remaining clips: шаг 3, изображение 2 из 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Remove the back cover: шаг 4, изображение 1 из 3 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Remove the back cover: шаг 4, изображение 2 из 3 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Disconnect the battery: шаг 5, изображение 1 из 3 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Disconnect the battery: шаг 5, изображение 2 из 3 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Disconnect the battery: шаг 5, изображение 3 из 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Wi-Fi Card: шаг 6, изображение 1 из 2 HP EliteBook x360 830 G6 Wi-Fi Card Replacement, Wi-Fi Card: шаг 6, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Remove the two antenna cable with tweezers.
    • The blue tagged antenna will be on the left side. The red tagged antenna will be on the right side.
  7. HP EliteBook x360 830 G6 Wi-Fi Card Replacement: шаг 7, изображение 1 из 2 HP EliteBook x360 830 G6 Wi-Fi Card Replacement: шаг 7, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the 3 mm screw securing the Wi-Fi card.
    • The card will pop up at a slight angle once the screw is removed.
  8. HP EliteBook x360 830 G6 Wi-Fi Card Replacement: шаг 8, изображение 1 из 2 HP EliteBook x360 830 G6 Wi-Fi Card Replacement: шаг 8, изображение 2 из 2
    • Grasp the sides of the Wi-Fi card to slide it out of the socket to remove.
    • Gently remove the Wi-Fi card. There is risk of damage to the socket if removed forcefully.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Еще один человек закончил это руководство.
Aeronel Jabile
Участник с: 09/01/21
316 Репутация
Автор 2 руководств
Команда
Gateway, Team 1-2, Saknee Fall 2021 Участник Gateway, Team 1-2, Saknee Fall 2021
GCC-SAKNEE-F21S1G2
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 769
