Введение
Use this guide if you are experiencing difficulty with your battery, especially if your laptop is over five years old. If the battery does not fully charge or your computer only turns on when plugged in, it may be time to replace your battery. This guide provides detailed instructions to replace your laptop’s battery.
Выберете то, что вам нужно
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
Pry open the lower case from where it meets the laptop base.
Remove the lower case from the work area.
Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
Carefully remove the power supply connector by pulling on both sides of its head.
Lift the battery from its position, removing it from the device.
Еще один человек закончил это руководство.
