HP Pavilion 15-eh SSD Replacement
Выберете то, что вам нужно
  1. HP Pavilion 15-eh SSD Replacement, Prepare your laptop for disassembly: шаг 1, изображение 1 из 1
    • Fully shut down your laptop and unplug all cables.
  2. HP Pavilion 15-eh SSD Replacement, Flip your laptop over: шаг 2, изображение 1 из 1
    • Flip your laptop over so the rubber feet are facing up.
  3. HP Pavilion 15-eh SSD Replacement, Expose the back cover screws: шаг 3, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement, Expose the back cover screws: шаг 3, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement, Expose the back cover screws: шаг 3, изображение 3 из 3
    • The ends of the rubber feet cover four back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
    • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
  4. HP Pavilion 15-eh SSD Replacement: шаг 4, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement: шаг 4, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Tesa 61395 Tape
    $5.99
    Купить
    • Peel up the other ends of the feet to expose the three remaining screws.
    • During reassembly:
    • Press down firmly on the ends of the feet to secure them into their recesses.
    • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
  5. HP Pavilion 15-eh SSD Replacement, Unfasten the back cover: шаг 5, изображение 1 из 2 HP Pavilion 15-eh SSD Replacement, Unfasten the back cover: шаг 5, изображение 2 из 2
    • Use a Phillips screwdriver to remove the six screws securing the back cover:
    • Four larger 6.6 mm-long black screws
    • Two smaller 4.8 mm-long silver screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  6. HP Pavilion 15-eh SSD Replacement, Release the clips: шаг 6, изображение 1 из 2 HP Pavilion 15-eh SSD Replacement, Release the clips: шаг 6, изображение 2 из 2
    • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the left of the right hinge.
    • Pry up with the spudger to release the clips securing the top right corner of the back cover.
  7. HP Pavilion 15-eh SSD Replacement: шаг 7, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement: шаг 7, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement: шаг 7, изображение 3 из 3
    • Insert the flat end of a spudger between the top right corner of the back cover and frame.
    • Slide the spudger down to the bottom right corner to release the clips on the right edge.
  8. HP Pavilion 15-eh SSD Replacement: шаг 8, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement: шаг 8, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement: шаг 8, изображение 3 из 3
    • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
    • Slide the spudger to the bottom left corner to release the clips.
  9. HP Pavilion 15-eh SSD Replacement: шаг 9, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement: шаг 9, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement: шаг 9, изображение 3 из 3
    • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
    • Slide the spudger up to the top left corner to release the clips on the left edge.
  10. HP Pavilion 15-eh SSD Replacement: шаг 10, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement: шаг 10, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement: шаг 10, изображение 3 из 3
    • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the right of the left hinge.
    • Slide the spudger towards the right hinge to release the remaining clips.
  11. HP Pavilion 15-eh SSD Replacement, Remove the back cover: шаг 11, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement, Remove the back cover: шаг 11, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement, Remove the back cover: шаг 11, изображение 3 из 3
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
  12. HP Pavilion 15-eh SSD Replacement, Unfasten the battery: шаг 12, изображение 1 из 2 HP Pavilion 15-eh SSD Replacement, Unfasten the battery: шаг 12, изображение 2 из 2
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the battery.
  13. HP Pavilion 15-eh SSD Replacement, Remove the battery: шаг 13, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement, Remove the battery: шаг 13, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement, Remove the battery: шаг 13, изображение 3 из 3
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Remove the battery.
    • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  14. HP Pavilion 15-eh SSD Replacement, Remove the SSD screw: шаг 14, изображение 1 из 2 HP Pavilion 15-eh SSD Replacement, Remove the SSD screw: шаг 14, изображение 2 из 2
    • Use a Phillips screwdriver to remove the 2.5 mm-long screw securing the SSD.
  15. HP Pavilion 15-eh SSD Replacement, Remove the SSD: шаг 15, изображение 1 из 3 HP Pavilion 15-eh SSD Replacement, Remove the SSD: шаг 15, изображение 2 из 3 HP Pavilion 15-eh SSD Replacement, Remove the SSD: шаг 15, изображение 3 из 3
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the SSD by its edges and pull it away from its M.2 board connector to remove it.
    • When removing the SSD, its thermal pad may lift up with it. If this happens, remove it and re-adhere it to its spot on the motherboard for use with a replacement SSD.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
Заключение
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
4 участников успешно повторили данное руководство.
Spencer Day
Участник с: 09/14/22
55 203 Репутация
Автор 408 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 430 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 9
За последние 30 дней: 64
За всё время: 879
