Введение
This guide will walk you through replacing the screen or display on your Hott T725-8G.
You will need to use the two replacement guides below:
Выберете то, что вам нужно
Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
Remove the display from the plastic casing. The screen is now ready for replacement.
2 участников успешно повторили данное руководство.
