Hott T725-8G Battery Replacement
Выберете то, что вам нужно
    1. Hott T725-8G Battery Replacement, Back Panel: шаг 1, изображение 1 из 1
      • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
      Спросите у FixBot
      Добавить комментарий
    2. Hott T725-8G Battery Replacement: шаг 2, изображение 1 из 1
      • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
      • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
      Спросите у FixBot
    3. Hott T725-8G Battery Replacement: шаг 3, изображение 1 из 1
      • Carefully dislodge the speaker from the back panel.
      Спросите у FixBot
    1. Hott T725-8G Battery Replacement, Battery: шаг 4, изображение 1 из 1
      • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
      Спросите у FixBot
    2. Hott T725-8G Battery Replacement: шаг 5, изображение 1 из 1
      • Use your fingers to separate the ribbon wire from the battery and the back of the display.
      Спросите у FixBot
    3. Hott T725-8G Battery Replacement: шаг 6, изображение 1 из 1
      • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
      Спросите у FixBot
    4. Hott T725-8G Battery Replacement: шаг 7, изображение 1 из 1
      • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
      Спросите у FixBot
    5. Hott T725-8G Battery Replacement: шаг 8, изображение 1 из 1
      • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
      • Avoid using metal when working with batteries.
      • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
      Спросите у FixBot
    6. Hott T725-8G Battery Replacement: шаг 9, изображение 1 из 1
      • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Emma Carroll
Участник с: 10/20/16
220 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 6-2, Martin Fall 2016 Участник UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 членов
Автор 11 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 31
За всё время: 693
