How to Apply Flash Unit Adhesives in Your Google Pixel 8a
Выберете то, что вам нужно
  1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: шаг 1, изображение 1 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: шаг 1, изображение 2 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: шаг 1, изображение 3 из 3
    • Use tweezers to remove the conductive tape adhesive from the top right corner of the motherboard cover.
    • Use the flat end of a spudger to scrape up any remaining bits of adhesive.
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the adhesive residue and wipe it away with a microfiber cloth.
  2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 2, изображение 1 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 2, изображение 2 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 2, изображение 3 из 3
    • Remove the conductive tape adhesive from its larger clear backing and put it into place with the tab on the right.
    • Use the flat end of a spudger to press down and secure the conductive tape.
    • Remove the remaining liner.
  3. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: шаг 3, изображение 1 из 2 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: шаг 3, изображение 2 из 2
    • Check the condition of the adhesive on the bottom of the flash unit.
    • If the adhesive is undamaged and still sticky, you can skip the rest of this guide and return to your original repair guide.
    • If the adhesive is damaged or no longer sticky, follow the next three steps to replace it.
  4. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 4, изображение 1 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 4, изображение 2 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 4, изображение 3 из 3
    • During the remaining steps, be very careful not to strain or tear the delicate flash unit cable.
    • Use a spudger and tweezers to carefully scrape up and remove the old adhesive from the bottom of the flash unit.
  5. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 5, изображение 1 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 5, изображение 2 из 3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 5, изображение 3 из 3
    • Remove the flash unit adhesive from its larger, clear liner and put it into place on the bottom of the flash unit.
    • Use the flat end of a spudger to press down and secure the adhesive.
  6. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: шаг 6, изображение 1 из 1
    • Firmly press the flash unit into place on the logic board cover to secure it with the adhesive.
    • Return to your original guide and continue with reassembly.
Заключение
Еще один человек закончил это руководство.
Spencer Day
Участник с: 09/14/22
149 568 Репутация
Автор 995 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 623 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 29
За всё время: 521
