How to Fix Left Joy-Con Sync Issues
Выберете то, что вам нужно
Видеоинструкции
Заключение
12 человек успешно провели ремонт по этому руководству.
Taylor Dixon
Участник с: 06/26/18
71 975 Репутация
Автор 94 руководств
7 Комментарии к руководству
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Ответить Поделиться
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - Поделиться
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Ответить Поделиться
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Ответить Поделиться
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 25
За последние 7 дней: 150
За последние 30 дней: 866
За всё время: 47,725
