How to Install a New Battery in Your Google Pixel 8 Pro
Выберете то, что вам нужно
  1. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: шаг 1, изображение 1 из 3 How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: шаг 1, изображение 2 из 3 How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: шаг 1, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • In order for the battery to properly adhere, you must remove all the old adhesive and its residue.
    • Use the flat end of a spudger to scrape up and remove all the old adhesive from the frame.
    • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
    • Use your fingers or tweezers to pick off big chunks.
  2. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive residue: шаг 2, изображение 1 из 1
    Microfiber Cleaning Cloths
    $3.99
    • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: шаг 3, изображение 1 из 2 How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: шаг 3, изображение 2 из 2
    • Lay the battery in its recess and temporarily reconnect it to the logic board to check its fit and cable length before adhering it.
    • Once you've found the proper alignment, disconnect the battery and remove it.
  4. How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: шаг 4, изображение 1 из 3 How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: шаг 4, изображение 2 из 3 How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: шаг 4, изображение 3 из 3
    Tesa 61395 Tape
    $5.99
    • If your battery comes with adhesive pre-installed, remove the plastic liner and firmly press the battery into its recess to secure it with the adhesive.
    • If your battery doesn't have pre-installed adhesive, apply strips of double-sided tape such as Tesa Tape where the old adhesive was and firmly press the battery into its recess to secure it.
Заключение
Еще один человек закончил это руководство.
Spencer Day
Участник с: 09/14/22
149 209 Репутация
Автор 995 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 608 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 27
За последние 30 дней: 100
За всё время: 1,977
