How to Open Your Logitech G Pro X Superlight
Выберете то, что вам нужно
  1. How to Open Your Logitech G Pro X Superlight, Prepare your mouse for disassembly: шаг 1, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight, Prepare your mouse for disassembly: шаг 1, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight, Prepare your mouse for disassembly: шаг 1, изображение 3 из 3
    • Slide your mouse's power switch down so it's in the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your mouse.
    • Flip the mouse over so the feet are facing up.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. How to Open Your Logitech G Pro X Superlight, Remove the feet: шаг 2, изображение 1 из 1
    • The feet are secured to the bottom of the mouse with strong adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. How to Open Your Logitech G Pro X Superlight: шаг 3, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight: шаг 3, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight: шаг 3, изображение 3 из 3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under the circular foot, making sure it goes under both the foot and its adhesive pad.
    • The foot recesses have a small notch that makes it easier to slide your spudger under.
    • Gently slide the spudger farther under the foot and lift until you can grab it with your fingers.
  4. How to Open Your Logitech G Pro X Superlight: шаг 4, изображение 1 из 2 How to Open Your Logitech G Pro X Superlight: шаг 4, изображение 2 из 2
    • Peel up and remove the foot.
    • If the rubber layer separated from its adhesive pad, use the same process to remove the pad.
  5. How to Open Your Logitech G Pro X Superlight: шаг 5, изображение 1 из 1
  6. How to Open Your Logitech G Pro X Superlight, Reassembly information: шаг 6, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight, Reassembly information: шаг 6, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight, Reassembly information: шаг 6, изображение 3 из 3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  7. How to Open Your Logitech G Pro X Superlight, Separate the shells: шаг 7, изображение 1 из 2 How to Open Your Logitech G Pro X Superlight, Separate the shells: шаг 7, изображение 2 из 2
    • Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the bottom shell.
  8. How to Open Your Logitech G Pro X Superlight: шаг 8, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight: шаг 8, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight: шаг 8, изображение 3 из 3
    • Don't try to fully separate the shells yet, as two cables still connect them.
    • Gently pull the top and bottom shells apart.
  9. How to Open Your Logitech G Pro X Superlight: шаг 9, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight: шаг 9, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight: шаг 9, изображение 3 из 3
    • Set your mouse down with the bottom shell on the workspace and the top shell flipped over the right edge.
    • Use an object such as a small box or stack of books to prop up the top shell so you can access the cables without straining them.
  10. How to Open Your Logitech G Pro X Superlight, Disconnect the shell cables: шаг 10, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight, Disconnect the shell cables: шаг 10, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight, Disconnect the shell cables: шаг 10, изображение 3 из 3
    • Use the point of a spudger to lift the locking flap on the top shell ZIF connector.
    • Use tweezers to gently pull the cable straight out of its socket.
    • During reassembly, insert the cable into its socket up to the white line before flipping down the locking flap.
  11. How to Open Your Logitech G Pro X Superlight: шаг 11, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight: шаг 11, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight: шаг 11, изображение 3 из 3
    • Flip the top shell onto the mouse and let it rest so it's partially hanging over the left side, giving you access to the battery connector on the right edge.
  12. How to Open Your Logitech G Pro X Superlight: шаг 12, изображение 1 из 3 How to Open Your Logitech G Pro X Superlight: шаг 12, изображение 2 из 3 How to Open Your Logitech G Pro X Superlight: шаг 12, изображение 3 из 3
    • Insert each arm of a pair of angled tweezers into the top of the cutouts on the right edge of the battery connector—the tweezers should curve upward.
    • Gently press the tweezers in and up to push the connector out of its socket enough that you can get a firm grip with your tweezers.
    • You may need to repeat this multiple times before the connector starts to come out.
  13. How to Open Your Logitech G Pro X Superlight: шаг 13, изображение 1 из 1
    • Use tweezers to grip the battery connector and pull it straight up and out of its socket.
    • During reassembly, push down on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
  14. How to Open Your Logitech G Pro X Superlight, The shells are separated: шаг 14, изображение 1 из 1
    • Remove the top shell from the bottom shell.
Заключение
4 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
149 834 Репутация
Автор 995 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 638 руководств
1 Комментарий к руководству
Hey there, thanks for detailed description.
I was a bit hard with the step below and broke the locking flap of the connector( What is the part number for the connector so I can purchase the donor?
NoX - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 45
За последние 7 дней: 401
За последние 30 дней: 1,847
За всё время: 19,614
