How to Perform a Battery Cycle Reset
  1. How to Perform a Battery Cycle Reset, Download the app: шаг 1, изображение 1 из 3 How to Perform a Battery Cycle Reset, Download the app: шаг 1, изображение 2 из 3 How to Perform a Battery Cycle Reset, Download the app: шаг 1, изображение 3 из 3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
    The Self Repair Assistant is now working on one ui 6.1
    Jayson Chua - Ответить
    Je trouve mas l'application
    Oussama Reddaf - Ответить
    Make sure to set your phone date to year 2022 before using this app version. If you don't, it will not work and ask you to download the latest version.
    Do not use the latest version of this app as it will ask for Samsung-made battery serial number (really Samsung. copying Apple for this is anti-consumer).
    Peter Chang - Ответить
  2. How to Perform a Battery Cycle Reset, Install the app: шаг 2, изображение 1 из 2 How to Perform a Battery Cycle Reset, Install the app: шаг 2, изображение 2 из 2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
    It says model not supported
    kayceegovender24 - Ответить
  3. How to Perform a Battery Cycle Reset, Rename the app: шаг 3, изображение 1 из 3 How to Perform a Battery Cycle Reset, Rename the app: шаг 3, изображение 2 из 3 How to Perform a Battery Cycle Reset, Rename the app: шаг 3, изображение 3 из 3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: шаг 4, изображение 1 из 3 How to Perform a Battery Cycle Reset: шаг 4, изображение 2 из 3 How to Perform a Battery Cycle Reset: шаг 4, изображение 3 из 3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
    Su s20 con one ui 5.1 viene fuori il messaggio di aggiornare l app
    _matti_ - Ответить
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: шаг 5, изображение 1 из 2 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: шаг 5, изображение 2 из 2
    • Select the Galaxy Cal app.
    Bei meinem S20 FE 5G kommt beim Starten der App die Meldung:
    This Model is NOT Supported
    Gibt es sonst noch eine Möglichkeit?
    DasMarki _ - Ответить
    Says galaxy s20fe is not supported?
    Leroy Henkeman - Ответить
    I want FE support as I have an S20 FE 5G.
    Evan Mcgeehan - Ответить
    It doesn't work on galaxy s20 with one ui 5.1
    _matti_ - Ответить
    On my S9 it installs but the window of the app closes instantly after opening.
    Rbn Vn Drn - Ответить
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: шаг 6, изображение 1 из 1
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: шаг 7, изображение 1 из 2 How to Perform a Battery Cycle Reset, Select the procedure: шаг 7, изображение 2 из 2
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: шаг 8, изображение 1 из 3 How to Perform a Battery Cycle Reset: шаг 8, изображение 2 из 3 How to Perform a Battery Cycle Reset: шаг 8, изображение 3 из 3
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
    _matti_ - Ответить
Финишная черта
11 человек успешно провели ремонт по этому руководству.
Alex Diaz-Kokaisl
Участник с: 01/16/22
161 981 Репутация
Автор 769 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 410 руководств
33 Комментариев
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - Ответить
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
When opening the app it says model not supported .I'm using a galaxy-s20-fe
Sankt Florian - Ответить
me too. cant find in store either
Chad Paul -
Set your phone date between 2021 to 2022
蓝泽希 -
Please update the newest version
kramyeu - Ответить
Hello again, when the prompt show there yoy should get new version just simple change the date back in past
kramyeu - Ответить
Good catch! I changed it to Sept 30 2022 and then the app started.
Oscar de León -
I installed the galaxy cal app on an S20, Android 13 too and when opening the app I get a message to try again after getting new version.
Tried on 3 devices, same result :(
Holger Dahlke - Ответить
Resetting the date was the right clue, thx :)
Holger Dahlke -
I have the same question that the application shows it needs updating before opening it. Version is SM-G9860, Oneui5.1
James Zhao - Ответить
note20 ultra show : This model is NOT supported! could you add note20 to this tool?
Fixxx - Ответить
I hope to see an increase in compatibility for the Note20 series.
Kaiming Zhang (土豆丝) - Ответить
Can you please add support for the fe series devices because I have an s20 fe 5g and need to replace my battery.
Would be nice to have, but not possible. As the Prolog says:
Diese Vorgehensweise funktioniert nur auf dem S20, S21, S22 und TabS7+ Modellen. Sie gilt nicht für Fan Edition (FE) Modelle. Diese Anleitung wird aktualisiert, sobald Samsung weitere Modelle hinzufügt.
"... Not suitable for the Fan Edition (FE) Modells. ..."
BenZ78 -
Can you please add s23 series support for in the future as I have an S23 Ultra. Also for those of you who have the "try again after getting new version" error just change your device's date to Oct. 1st 2022 or earlier.
No need to change the phones date just update the app after installing using the galaxy store.
Chris - Ответить
Does it work with a S20+ too?
Daniel - Ответить
Hallo,
danke für Euren Tipp.
Ich habe diese Version für mein S22 plus heruntergeladen und installiert. Nach dem Start der App, wollte die App aktualisiert werden. Habe ich gemacht und jetzt will die App eine Seriennummer meines Akkus. Version 2.0.10
Kann ich das irgend wie auslesen lassen?
Mfg
dachs1 - Ответить
Is there a compatible version for the Samsung S10E?
Elia Capecci - Ответить
Did you try the latest version 2.0.12 from the Samsungparts link in step 1 in the unverified but updated version of this guide?
Evan Mcgeehan -
Hi all. Why doesn't the program support Samsung 20FE? Is there a way to reset the charge counter?
Андрей Александров - Ответить
Hallo
Leider sagt die app das ei e Verwendung auf dem s21fe nicht möglich ist. Gibt es dafür Lösungsansätze?
benbaschke - Ответить
Use the latest version 2.0.12 in the unverified version of this guide. I tested it on devices in Samsung's Remote Test Lab and it should work for your S21FE.
Verwenden Sie die neueste Version 2.0.12 in der nicht verifizierten Version dieses Handbuchs. Ich habe es auf Geräten im Remote Test Lab von Samsung getestet und es sollte für Ihr S21FE funktionieren.
Evan Mcgeehan -
Change phone date to 2021
jackyang0320 -
when i start the calibration, the apps shows that need a serial or qr of the battery, how can i get it?
juandavidflexia - Ответить
at the back of the battery there is QR code or at the front I am not so sure which one to use. there is also serial number beside the QR code at the back
Ray Floyd Cabrera -
Hallo, can i use it for my galaxy S21 5G ?
Johann Gottlieb - Ответить
Yes I've tested it on that model in Samsung's Remote Test Lab on their developer website and it works.
Evan Mcgeehan -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 110
За последние 7 дней: 683
За последние 30 дней: 2,797
За всё время: 74,551
