Введение
Follow this guide to remove and replace a plastic snap (aka snap fastener, snap button, or press button) using a handheld fastener tool.
Before you begin, check the fabric around the old snap for tears or damage beyond a small hole. If the fabric is compromised, you'll need to sew a reinforcing patch before replacing the snap.
If you're installing a brand new snap, check out this guide.
If you're replacing a metal snap, follow this guide instead.
Выберете то, что вам нужно
Use pliers to crush the plastic snap until it loosens from the fabric.
Remove and discard the broken plastic snap pieces.
Push the point of an awl through the fabric hole to clear it for the cap.
Use your fingers to squeeze a cap pin through the fabric hole.
Center the snap components in the fastener tool. The cap should sit fully in the black die cup.
Firmly squeeze the fastener tool handles. The white rubber head should bulge slightly from the force.
Release the handles and remove the tool from the snap.
Visually inspect the snap. The center pin should be evenly flattened.
Pull on the snap. The snap shouldn't feel loose.
Repeat the procedure to install the other half of the snap set.
For more clothing repair guides, click here.
