How to Use the FixHub Web Console
    1. How to Use the FixHub Web Console, Plug in your iron: шаг 1, изображение 1 из 1
      • To use the FixHub Web Console, you need a browser with Web Serial enabled. We recommend Brave, Chrome, Edge, or Opera as they include this functionality enabled by default.
      • Firefox and Safari don't support Web Serial at this time.
      • Plug the cable included with your iron or any USB cable that supports data transfer into your computer.
      • Navigate to iFixit.com/FixHub/console
      Спросите у FixBot
      Добавить комментарий
    2. How to Use the FixHub Web Console, Connect your iron: шаг 2, изображение 1 из 3 How to Use the FixHub Web Console, Connect your iron: шаг 2, изображение 2 из 3 How to Use the FixHub Web Console, Connect your iron: шаг 2, изображение 3 из 3
      • Click Connect my device.
      • Select your Smart Soldering Iron from the pop-up window asking you to connect a serial port.
      • Click Connect.
      Спросите у FixBot
    3. How to Use the FixHub Web Console, FixHub Web Console layout: шаг 3, изображение 1 из 1
      • Once the FixHub Web Console opens, you'll see temperature settings, current status, and other information:
      • Current temperature shows the tip temperature in real time.
      • Set temperature allows you to change the iron's temperature with a slider.
      • Status reflects the current status of the iron.
      • Settings allows you to change iron settings such as idle temperature and sleep timer.
      • Serial number shows the serial number of the connected iron.
      • Version shows the firmware version of the connected iron.
      Спросите у FixBot
    4. How to Use the FixHub Web Console, Firmware update: шаг 4, изображение 1 из 3 How to Use the FixHub Web Console, Firmware update: шаг 4, изображение 2 из 3 How to Use the FixHub Web Console, Firmware update: шаг 4, изображение 3 из 3
      • Before using the FixHub Web Console, ensure your firmware is up to date.
      • Select the Version box.
      • Click Update now and wait for the firmware update to complete. Don't disconnect your iron or close the window during the firmware update.
      • Once the soldering iron updates successfully, be sure to update the Portable Power Station firmware to the same version.
      • If something goes wrong, you can downgrade your firmware by repeating these steps and clicking Downgrade to an older firmware.
      Спросите у FixBot
    5. How to Use the FixHub Web Console, Adjust the set temperature: шаг 5, изображение 1 из 3 How to Use the FixHub Web Console, Adjust the set temperature: шаг 5, изображение 2 из 3 How to Use the FixHub Web Console, Adjust the set temperature: шаг 5, изображение 3 из 3
      • Drag the Set temperature slider to your desired temperature from 200 to 420 °C (395 to 790 °F).
      Спросите у FixBot
    6. How to Use the FixHub Web Console, Change the temperature scale: шаг 6, изображение 1 из 2 How to Use the FixHub Web Console, Change the temperature scale: шаг 6, изображение 2 из 2
      • You can reset all settings back to default at any time.
      • Click the Settings box.
      • At the top of the Settings window, select your desired unit for temperature under the Unit tab.
      Спросите у FixBot
    7. How to Use the FixHub Web Console, Adjust the idle temperature: шаг 7, изображение 1 из 3 How to Use the FixHub Web Console, Adjust the idle temperature: шаг 7, изображение 2 из 3 How to Use the FixHub Web Console, Adjust the idle temperature: шаг 7, изображение 3 из 3
      • A lower idle temperature will extend tip life, while a higher one will resume working temperature more quickly.
      • Drag the Idle temperature slider to your desired temperature from 50 to 200 °C (125 to 390 °F).
      Спросите у FixBot
    8. How to Use the FixHub Web Console, Adjust the idle timer: шаг 8, изображение 1 из 3 How to Use the FixHub Web Console, Adjust the idle timer: шаг 8, изображение 2 из 3 How to Use the FixHub Web Console, Adjust the idle timer: шаг 8, изображение 3 из 3
      • The idle timer can be disabled, but it's highly recommended to leave it enabled to prevent the iron cap from overheating and to extend tip life.
      • The idle timer setting adjusts how long the iron must be stationary before entering Idle Mode.
      • Drag the Idle timer slider to your desired time from 1s to 60s.
      Спросите у FixBot
    9. How to Use the FixHub Web Console, Adjust the sleep timer: шаг 9, изображение 1 из 2 How to Use the FixHub Web Console, Adjust the sleep timer: шаг 9, изображение 2 из 2
      • The sleep timer can be disabled, but doing so will cause the iron cap to overheat and the tip to degrade rapidly.
      • Drag the Sleep timer slider to your desired time from 1s to 60s.
      Спросите у FixBot
    10. How to Use the FixHub Web Console, Offset temperature based on external calibration: шаг 10, изображение 1 из 3 How to Use the FixHub Web Console, Offset temperature based on external calibration: шаг 10, изображение 2 из 3 How to Use the FixHub Web Console, Offset temperature based on external calibration: шаг 10, изображение 3 из 3
      • This setting lets you offset the temperature settings of your iron tips based on an external temperature sensor.
      • Drag the Temperature correction slider to the desired amount from -20 to +20 °C (-36 to 36 °F).
      Спросите у FixBot
    11. How to Use the FixHub Web Console, Calibrate the accelerometer: шаг 11, изображение 1 из 2 How to Use the FixHub Web Console, Calibrate the accelerometer: шаг 11, изображение 2 из 2
      • This setting lets you calibrate the accelerometer in the iron by setting it completely still.
      • Click Go to calibration to open the Accelerometer Calibration page.
      • Set the iron down on a stationary object with the power switch facing up. Click Calibrate to set the current magnitude (shown in the line graph on the page) as the iron's resting state.
      Спросите у FixBot
Заключение
That's it! You're ready to configure your Smart Soldering Iron to your individual preferences.
Still struggling? Try some basic troubleshooting, or ask our Answers community for help.
6 человек успешно провели ремонт по этому руководству.
Nick Schultz
Участник с: 03/24/24
59 266 Репутация
Автор 318 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 45 628 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 64
За последние 30 дней: 260
За всё время: 4,455
