Huawei P9 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Huawei P9 Front Facing Camera Replacement, Back Cover: шаг 1, изображение 1 из 3 Huawei P9 Front Facing Camera Replacement, Back Cover: шаг 1, изображение 2 из 3 Huawei P9 Front Facing Camera Replacement, Back Cover: шаг 1, изображение 3 из 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Front Facing Camera Replacement: шаг 2, изображение 1 из 2 Huawei P9 Front Facing Camera Replacement: шаг 2, изображение 2 из 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: шаг 3, изображение 1 из 2 Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: шаг 3, изображение 2 из 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: шаг 4, изображение 1 из 3 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: шаг 4, изображение 2 из 3 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: шаг 4, изображение 3 из 3
    • Peel off the conducting fabric.
    • You will have to transfer it to the new camera (careful it's sticky).
    • Unplug the camera connector.
    • Now you can remove the front camera.
Заключение
Еще один человек закончил это руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
250 040 Репутация
Автор 682 руководств
Команда
iFixit EU Team Участник iFixit EU Team
Staff
37 членов
Автор 1 211 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 35
За всё время: 1,925
