Введение
Use this guide to replace the motherboard in your Huawei Watch GT 2 (42 mm).
Выберете то, что вам нужно
Before starting the repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a T2 Torx screwdriver to remove the four 3.6 mm screws securing the back cover assembly.
Insert an opening tool in the seam on the top edge between the back cover assembly and the watch case.
Use the opening tool to pry up the back cover assembly of your Huawei Watch GT 2 (42 mm).
Carefully swing the back cover assembly open to an upward position.
Insert an opening pick in the gap between the metal shield and the shield bracket on the motherboard.
Push the opening pick slightly downwards to unhinge the metal shield.
Use a spudger to disconnect the back cover assembly.
Separate the back cover assembly from the watch case.
Remove the metal shield.
Use the pointed end of a spudger to disconnect the display flex cable from the motherboard.
Use a Phillips #00 screwdriver to remove the four 2.3 mm screws securing the motherboard.
