Введение
Use this guide to replace the Limit Switch that tells the Keurig that the K-Cup section is closed.
Выберете то, что вам нужно
While looking upwards from underneath the Keurig, remove the two 8mm Phillips #2 screws from underneath the black plastic "shroud".
Remove the black plastic "shroud" by pushing inwards and then pulling upwards to disengage the plastic hooks that are not visible.
Remove the switch by cuting the two connecting wires. Reconnect a replacement switch using this guide to join wires with solder, or using this guide to solder connections, or by using any other technique to connect wires.
Еще один человек закончил это руководство.
