Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
In this guide, you'll disconnect all components in order to replace a faulty or damaged motherboard in your LG G Watch R. Motherboard failure will typically stop your watch from working or even turning on. However, the motherboard is usually the most expensive part of the device to replace—so check the troubleshooting page to rule out other factors before replacing the motherboard. Since your data is stored on a chip on the motherboard, be aware that replacing the board will cause you to lose any saved data.
Выберете то, что вам нужно
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
Use a plastic opening tool to pry open the back case from both sides of the watch.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
3 участников успешно повторили данное руководство.
3 Комментариев
Where do I buy a replacement motherboard from??
Did you ever find anywhere to order a replacement motherboard?
