LG Refrigerator Control Board Replacement
Выберете то, что вам нужно
  1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: шаг 1, изображение 1 из 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Control Board Replacement, Unfasten the control board cover: шаг 2, изображение 1 из 1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Control Board Replacement, Remove the control board cover: шаг 3, изображение 1 из 3 LG Refrigerator Control Board Replacement, Remove the control board cover: шаг 3, изображение 2 из 3 LG Refrigerator Control Board Replacement, Remove the control board cover: шаг 3, изображение 3 из 3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Control Board Replacement, Disconnect the control board: шаг 4, изображение 1 из 3 LG Refrigerator Control Board Replacement, Disconnect the control board: шаг 4, изображение 2 из 3 LG Refrigerator Control Board Replacement, Disconnect the control board: шаг 4, изображение 3 из 3
    • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
    • Squeeze and pull the connectors to disconnect them from the control board.
    • Make sure to fully reconnect each connector when reassembling.
  5. LG Refrigerator Control Board Replacement, Release the control board: шаг 5, изображение 1 из 3 LG Refrigerator Control Board Replacement, Release the control board: шаг 5, изображение 2 из 3 LG Refrigerator Control Board Replacement, Release the control board: шаг 5, изображение 3 из 3
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
  6. LG Refrigerator Control Board Replacement: шаг 6, изображение 1 из 3 LG Refrigerator Control Board Replacement: шаг 6, изображение 2 из 3 LG Refrigerator Control Board Replacement: шаг 6, изображение 3 из 3
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
  7. LG Refrigerator Control Board Replacement, Remove the control board: шаг 7, изображение 1 из 1
    • Lift the control board out by its edges and remove it.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Участник с: 06/30/22
30 138 Репутация
Автор 213 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 442 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 34
За последние 30 дней: 148
За всё время: 481
