Введение
Use this guide to replace the compressor run capacitor in your LG model LFX25973 refrigerator.
The compressor run capacitor is needed for the compressor to run properly. If it fails, your compressor may not run or will run poorly.
If you are experiencing poor cooling or the compressor isn't functioning, the run capacitor is one of the items to check. There may not be an error code associated with this condition.
Выберете то, что вам нужно
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
Use a Phillips screwdriver to remove the three 18.4 mm‑long screws securing the control board cover.
Tilt the top edge of the cover toward you and lift it off.
Pull the left edge of the capacitor toward you to unclip it.
Pull the connector straight off the capacitor to disconnect it.
Remove the capacitor.
