Введение
Use this guide to remove the freezer light on your LG model LFX25973 refrigerator.
The freezer light allows you to see the contents of the freezer drawer more easily.
Выберете то, что вам нужно
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
Lift and remove the upper pull-out drawer.
Lift and remove the main drawer bin.
Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
Lift the cover off of the rail and remove it.
Repeat this procedure for the left drawer rail cover.
Hold the drawer rail cover flush against the side of the drawer rail.
Push the rail cover straight downward to install. It should click into place.
Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
Lift the front of the drawer up.
Pull the drawer toward you to release the drawer from the drawer slides.
Remove the freezer drawer.
Use a Phillips screwdriver to remove the 22 mm‑long screw securing the freezer light.
Lower the front edge of the freezer light to access its connector.
Squeeze the freezer light connector and pull it straight off to disconnect it.
Remove the freezer light.
