Введение
Use this guide to replace the ice and water dispenser on your LG model LFX25973 refrigerator.
The ice and water dispenser dispenses ice and water through the left refrigerator door. It has paddles that operate switches located in the dispenser, which control the output of ice and water from the dispenser.
The ice and water dispenser has a number of components that may need replacing, including the display PC board, the ice and water dispensing switches, and sub-control PC board.
If the ice and water dispenser fails, you will notice erratic operation of the ice and water dispensing functions. They may also completely cease operation.
Выберете то, что вам нужно
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Pull the left door handle straight off to remove it.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
Do not attempt to remove the four-wire connector from the board as it is not removable.
Squeeze and separate the two-wire harness connector and the four-wire harness connector.
Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
Lift and remove the circuit board holder from the dispenser assembly.
