Введение
Use this guide to replace the water inlet valve assembly on your LG refrigerator model LFX25973.
The water inlet valve assembly controls the flow of water to the dispenser and also to the ice makers.
If it fails, you may experience the following:
- Leaking and puddles on the floor near the refrigerator
- Water freezing on the bottom of your freezer
- Ice in your in-door dispenser freezing up and not dispensing
- No ice produced, or no water dispensed if the valve refuses to open at all
Выберете то, что вам нужно
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
Use a Phillips screwdriver to remove the six 14.5 mm‑long screws securing the condenser cover to the rear of the refrigerator.
Tilt the top edge of the condenser cover toward you.
Lift and remove the condenser cover.
Squeeze and pull down the yellow and white connectors to disconnect them.
Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the water inlet valve assembly.
Pull the water inlet valve assembly out of the refrigerator for better access to electrical connections and water tubing connections.
Squeeze and pull downward the remaining water inlet valve assembly connector to disconnect it.
Use long nose pliers to pull and remove the locking clip from the smaller white tubing connector.
Use your fingers to squeeze the flange surrounding the small white water tube toward the valve to release the tube.
While you squeeze the flange, pull the tubing straight out of the connector.
Repeat this procedure for the remaining tubes.
Remove the inlet valve assembly.
For the first solenoid, test the resistance between the red and blue wires on the white connector.
Repeat the test on the yellow connector for the other solenoid.
To test the flow meter, test the resistance between the red and black wires on the white connector.
