Введение
Use this guide to replace the control panel in your LG WM3050CW Washing Machine.
The control panel contains the buttons, dials, and control knob to adjust the wash settings. If you have a broken control knob or button, you can access it by following this guide.
Выберете то, что вам нужно
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
Tilt the top panel upward to completely disconnect it from the chassis.
Remove the top panel.
Pull the detergent drawer away from the chassis as far as it will go.
Press down on the "Push" button to disengage the clips securing the detergent drawer.
Pull the drawer out of its slot on the chassis and remove it.
Disconnect the three harness connectors for the control panel.
Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
Twist the screwdriver to release the clips securing the control panel.
Repeat this procedure for the remaining clips along the control panel.
Lift the control panel upward to completely separate it from the chassis.
Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
Remove the control panel.
Flip the control panel over.
Use a Phillips driver to remove the seven 16.4 mm-long screws securing the control panel board cover.
Pull the control panel board out of its slot and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
2 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
Thanks for this guide, it looks very easy to follow. I am thinking about replacing my control panel, it works fine except for one annoying problem, the ‘Start’ button is working intermittently. I need to push Start 2 or 3 times before the washer starts. Has anyone seen this? I may just disassemble the washer and see if I can blow out any debris.
Hello Jimjar! You can take a shot at blowing stuff out, It is probably the switch on the control panel board that is failing. especially if you don't have trouble with any of the other control buttons. So you might want to start by blowing out the start switch if you have a source of compressed air. While you handle these parts especially blowing air on them, make sure to handle them by the edges, and keep yourself grounded or at least touching something that is grounded frequently. Since the boards are encapsulated (note the honey colored material covering the board) to protect against corrosion, replacing components becomes a chore. So your next step will probably be a replacement control panel board if the cleaning doesn't help. There are services that will repair the board as well; haven't looked into relative cost. You can fix it, and that's a lot better than having to spend for another appliance.
The plastic in the control panel cover on my LG F2R3S0*NSW* washer seems to have spontaneously cracked on the left of the program selection wheel.
The controls work fine but it's so annoying to see on a 1 month old washer. Has anyone else run into this problem?
