Lasko CD08200 ACLI Safety Plug and Cable Replacement
Выберете то, что вам нужно
  1. Lasko CD08200 ACLI Safety Plug and Cable Replacement, ACLI Safety Plug and Cable: шаг 1, изображение 1 из 2 Lasko CD08200 ACLI Safety Plug and Cable Replacement, ACLI Safety Plug and Cable: шаг 1, изображение 2 из 2
    • Please disconnect the device and let it sit for 10 minutes so any fuses can drain before beginning this guide.
    • Turn over the device and place it on its head. Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 2, изображение 1 из 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 3, изображение 1 из 2 Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 3, изображение 2 из 2
    • Trace the two grey cables of the ACLI plug to their white wire connectors. Pinch the wire connector and pull out the wire connector with pliers.
    • Keep record of which independent wire went to which wire connector.
  4. Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 4, изображение 1 из 1
    • Heat up the end of the wire from the tip of the solder iron.
    • While the wire is still hot, untwist the wires using pliers.
    • If other wires are obstructing each other, you can cut the black zip tie holding together the wires for more room.
    • During reassembly, twist each independent end of wire into each other with pliers until the twisted wire’s end is pointed.
  5. Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 5, изображение 1 из 3 Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 5, изображение 2 из 3 Lasko CD08200 ACLI Safety Plug and Cable Replacement: шаг 5, изображение 3 из 3
    • Gently free the wire from the power cord casing with a spudger.
    • The cable may be too tight to pull out from the power cord casing. If you struggle to pull the cable out, use the pointed end of a spudger to free the cable from the power cord casing.
    • Pull the ACLI cable out from the power cord casing with your hands.
    • Pull the entire ACLI cable out of the device.
    • During reassembly, do not use a metal spudger to push the cable back into the power cord casing. You might break the cable’s insulation when applying force to the cable with a metal spudger.
Заключение
Artur Komissarov
Участник с: 01/14/20
403 Репутация
Автор 2 руководств
Команду
York University, Team S1-G1, Woodhouse Winter 2020 Участник York University, Team S1-G1, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G1
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 1,464
