Lefant M210 Brush Replacement
Выберете то, что вам нужно
  1. Lefant M210 Brush Replacement, Brush: шаг 1, изображение 1 из 2 Lefant M210 Brush Replacement, Brush: шаг 1, изображение 2 из 2
    • Turn off the Lefant M210 and disconnect it from the charging dock.
    • Flip the unit over so the bottom faces upward.
    • Locate the circular brush assemblies on the left and right sides of the underside.
    • Place the unit on a clean, flat surface to prevent scratching.
    Спросите у FixBot
  2. Lefant M210 Brush Replacement: шаг 2, изображение 1 из 3 Lefant M210 Brush Replacement: шаг 2, изображение 2 из 3 Lefant M210 Brush Replacement: шаг 2, изображение 3 из 3
    • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
    • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
    • Remove the brush assembly completely and set it aside.
    • If replacing both brush assemblies, repeat this process on the other side.
    • Avoid using excessive force, which may damage the mounting clips.
    Спросите у FixBot
    • Position the new brush assembly above the square mounting peg.
    • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
    • Press down firmly on the brush assembly until you hear or feel it click into place.
    • Gently tug on the brush to verify it is securely seated.
    • The brush should sit flush with the housing and not move when pulled gently.
    Спросите у FixBot
Заключение
If problems occur: Power off the unit, flip it over, and verify the brush is correctly aligned and fully seated. With fresh brushes installed, your robot vacuum is back in action and ready to keep your floors spotless!
Brittany I
Участник с: 09/09/24
173 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Участник CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 57
За всё время: 395
