Lenovo IdeaPad 120s-14IAP Battery Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad 120s-14IAP Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo IdeaPad 120s-14IAP Battery Replacement: шаг 2, изображение 1 из 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo IdeaPad 120s-14IAP Battery Replacement, Battery: шаг 3, изображение 1 из 1
    • Remove five 1.5mm Phillips screws from the battery edges.
  4. Lenovo IdeaPad 120s-14IAP Battery Replacement: шаг 4, изображение 1 из 1
    • Use your fingers or a spudger to unlock the wide ribbon cable's ZIF connector.
    • To unlock a ZIF connector, flip up the small, hinged locking flap.
    • Gently pull the connector from the battery side until it is fully detached from the daughterboard.
  5. Lenovo IdeaPad 120s-14IAP Battery Replacement: шаг 5, изображение 1 из 1
    • Gently pull the power harness away from the daughterboard until the connector is detached.
    • Pull parallel to the board, not straight up.
  6. Lenovo IdeaPad 120s-14IAP Battery Replacement: шаг 6, изображение 1 из 1
    • With the laptop oriented so that the long edge faces you and the battery is closest to you, carefully remove the battery by lifting on the longitudinal edge.
    • Pull the battery directly towards you and out from under the forward retaining strap.
Заключение
Еще один человек закончил это руководство.
Kyle P Sumpter
Участник с: 09/17/19
363 Репутация
Автор 2 руководств
Команда
2 Комментариев
Thank you for showing exactly how to remove the battery connections, thanks!
Erik Gunnar Gervin - Ответить
Great guide. I may well need a new battery but would appreciate your comment. Battery shows charging but never gets above 0%
When I put a meter at the 2 red cables they show zero volts (even when computer on, and showing charging). Other wires are ~1.6v & 3.4v.
Could I have a faulty battery or something else?
Colin Kinsella - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 47
За всё время: 5,189
