Введение
The heatsink (or heat sink) is a passive heat exchanger that transfers heat in a device. The heatsink disperses heat from another component in the device to prevent the device from overheating.
If you find that your laptop easily overheats or is running at higher temperatures than normal, it may be time to replace the heatsink. Follow these simple instructions to remove and replace the heatsink in your Lenovo IdeaPad Flex 5-1570 laptop. Make sure to turn off your laptop and let it cool for 20 minutes before proceeding with the guide.
Don’t forget to follow our thermal paste application guide after you have removed your heat sink and are ready to reassemble your device.
Выберете то, что вам нужно
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Use a spudger to pry open the back case at the two hinge cutouts.
Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
Remove the two 5 mm Phillips #00 screws that secure the battery in place.
Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
Remove the battery from the device.
Disconnect the wire holding the fan and the motherboard together.
Remove the fan from the device.
Don’t forget to reapply thermal paste during reassembly. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
Еще один человек закончил это руководство.
