Lenovo ThinkPad T460s Battery Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad T460s Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Battery Replacement: шаг 3, изображение 1 из 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Battery Replacement: шаг 4, изображение 1 из 3 Lenovo ThinkPad T460s Battery Replacement: шаг 4, изображение 2 из 3 Lenovo ThinkPad T460s Battery Replacement: шаг 4, изображение 3 из 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
13 участников успешно повторили данное руководство.
kewei xia
Участник с: 10/01/19
457 Репутация
Автор 2 руководств
Команда
12 Комментариев
I have a question, please. Are the two batteries identical?
Felipe L.R. - Ответить
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Jonas Andersen - Ответить
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 17
За последние 7 дней: 122
За последние 30 дней: 583
За всё время: 48,555
