Введение
You may need to access the internals of your Lenovo ThinkPad T480 or you may want to replace the back cover because of damage. In either case, follow this guide to replace the back cover of your Lenovo ThinkPad T480.
Be sure to disable to internal battery, power off, and unplug the charging cable prior to beginning this guide.
Выберете то, что вам нужно
Using your fingers, slide the lock on each side of the battery to the unlocked position.
Remove the battery from the slot.
Insert the blue plastic opening tool into the space between the lower case and the chassis.
Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
Remove the back case.
5 человек успешно провели ремонт по этому руководству.
2Комментарии к руководству
Dont forget the 3 clips in the removable battery area. No one mentioned those and I ended up breaking a clip and cracking the bottom cover of my T480... :(
Hey @neccros! Thanks for the feedback. I'm very sorry you cracked your bottom cover. I've updated the guide to incorporate your experience.
