Введение
Use this guide to replace the hinges in your Lenovo ThinkPad T480s laptop.
Laptop hinges that are in good condition will allow you to open the laptop lid with ease. The laptop hinges may be malfunctioning if you experience extreme stiffness or looseness when opening and closing the laptop lid. Other symptoms include the lid not shutting completely, the lid not staying open, dislocated hinges, or cracks around the hinges or in the hinges themselves.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Выберете то, что вам нужно
Remove the bottom cover with an opening tool.
Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
Use the spudger to remove the internal bezel.
Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
Peel back the tape covering the LCD cable connector.
Use the spudger to unlock the LCD cable.
Use the Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper right corner.
Use a Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper left corner.
