Введение
Use this guide to replace the speakers in your Lenovo ThinkPad T480s laptop.
If your laptop isn’t producing sound, or if the sound is distorted or intermittent, your speakers may be faulty. Be sure to troubleshoot any speaker-related issues before attempting to replace them.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Выберете то, что вам нужно
Remove the bottom cover with an opening tool.
Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
Disconnect the speaker cable from the motherboard using a connector puller or spudger.
Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
Lift the speakers up.
Disconnect the cable speakers from the routing.
Remove the speakers from the system.
