Введение
This guide will show you how to replace the Wi-Fi card in a Lenovo ThinkPad T480s laptop.
A Wi-Fi card, also known as a WLAN card, enables the laptop to connect to a wireless network. If you cannot connect your laptop to Wi-Fi, or if you are experiencing intermittent connectivity, you may have a faulty Wi-Fi card. Be sure to rule out other connectivity issues listed here before replacing your Wi-Fi card.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Выберете то, что вам нужно
Remove the bottom cover with an opening tool.
Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
