Lenovo ThinkPad T490s Back Cover Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad T490s Back Cover Replacement, Loosen the back screws: шаг 1, изображение 1 из 2 Lenovo ThinkPad T490s Back Cover Replacement, Loosen the back screws: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Back Cover Replacement, Release the clips: шаг 2, изображение 1 из 2 Lenovo ThinkPad T490s Back Cover Replacement, Release the clips: шаг 2, изображение 2 из 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Back Cover Replacement: шаг 3, изображение 1 из 2 Lenovo ThinkPad T490s Back Cover Replacement: шаг 3, изображение 2 из 2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Back Cover Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Lenovo ThinkPad T490s Back Cover Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Lenovo ThinkPad T490s Back Cover Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
Участник с: 09/19/22
68 032 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
137 членов
Автор 17 524 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 72
За всё время: 1,217
