Lenovo ThinkPad T490s SSD Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: шаг 1, изображение 1 из 2 Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s SSD Replacement, Release the clips: шаг 2, изображение 1 из 2 Lenovo ThinkPad T490s SSD Replacement, Release the clips: шаг 2, изображение 2 из 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s SSD Replacement: шаг 3, изображение 1 из 2 Lenovo ThinkPad T490s SSD Replacement: шаг 3, изображение 2 из 2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: шаг 5, изображение 1 из 2 Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: шаг 5, изображение 2 из 2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: шаг 6, изображение 1 из 2 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: шаг 6, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove the 3.7 mm-long screw holding down the SSD.
  7. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: шаг 7, изображение 1 из 3 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: шаг 7, изображение 2 из 3 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: шаг 7, изображение 3 из 3
    • Pull the SSD out and away from its socket.
    • If this motion requires excessive force, walk the SSD side to side as you pull.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
2 участников успешно повторили данное руководство.
Clay Eickemeyer
Участник с: 09/19/22
66 953 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 218 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 52
За последние 30 дней: 241
За всё время: 3,599
