Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: шаг 1, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to loosen the five captive screws holding the back cover.
  2. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: шаг 2, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: шаг 2, изображение 2 из 2
    • Insert an opening pick between a corner of the back cover and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when clips release.
    • Repeat this process for the opposite corner.
  3. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: шаг 3, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: шаг 3, изображение 2 из 2
    • Insert the opening pick between the cover and the body.
    • Pry upward and release all of the retaining clips.
  4. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: шаг 4, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: шаг 4, изображение 2 из 2
    • Lift the back cover off the chassis and remove it.
    • If the cover feels stuck to the chassis, use an opening pick to release any remaining clips around the perimeter of the back cover.
  5. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: шаг 5, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: шаг 5, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove the six 4.9 mm screws securing the battery to the laptop chassis.
  6. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: шаг 6, изображение 1 из 3 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: шаг 6, изображение 2 из 3 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: шаг 6, изображение 3 из 3
    • Grip the corners of the battery.
    • Pull and lift the battery of its recess and remove it.
    • Be delicate when pulling the battery out at first. The small pins on its connector are easy to bend.
    • There is no cable for the battery. It disconnects when removed from its recess.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon community for help.
Clay Eickemeyer
Участник с: 09/19/22
67 312 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 430 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 103
За последние 30 дней: 442
За всё время: 4,788
