Введение
The touchpad (or also known as trackpad) is an essential component of a laptop and tracks the motion and position of a user’s fingers to a position on the screen. A functioning touchpad is important to the portability of a laptop, and if your touchpad is unresponsive, you may need to use an external mouse to use your device. A failing touchpad may exhibit the following symptoms:
- Cursor isn’t responding to touchpad movements.
- Cursor is slow to respond.
- Cursor is jumping to every movement.
If your laptop is having a difficult time tracking your movements or if your trackpad is unresponsive, it may be time to replace the touchpad in your device. Follow these steps to remove and replace the touchpad in your Lenovo ThinkPad T450.
Выберете то, что вам нужно
Using your hands, slide the two locking tabs away from each other to release the battery.
Slide the battery up and out of the device.
Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
Remove the back cover from the device.
Using the JIS #00 screwdriver, remove the single 2.8 mm screw securing the SSD to the device.
Lift up the black piece of tape and remove it to uncover the RAM sticks underneath.
Using your fingers, push the two clips securing the RAM away from each other to release the RAM.
Remove the RAM stick from the device.
Using the JIS #00 screwdriver, unscrew the four screws securing the fan and heatsink assembly to the motherboard.
Disconnect the fan and heatsink assembly from the motherboard using the plastic opening tool.
Lift and remove the black piece of plastic to expose the Wi-Fi card.
Use the plastic opening tool to remove the black piece of tape holding the cables together.
Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the motherboard.
Remove the black plastic covering the motherboard.
Using the plastic opening tool, disconnect the CMOS battery from the motherboard.
Insert the plastic opening tool underneath the CMOS battery and pry it up and away from the motherboard.
Use the JIS #00 screwdriver to remove two 2.8 mm screws securing the display cable bracket to the motherboard.
Remove the display cable bracket from the device.
Disconnect the daughterboard cable and the display cable using the plastic opening tool.
Using the JIS #00 screwdriver, remove the single 5 mm screw securing the bracket to the motherboard.
Remove the metal bracket from the device.
Disconnect the speaker cable from the motherboard using the plastic opening tool.
Using the plastic opening tool, flip up the locking tab on the zero insertion force (ZIF) connector and disconnect the cable from the motherboard.
Using a plastic opening tool, disconnect the smartcard reader cable from the motherboard.
Using the same plastic opening tool, flip up the locking tab and disconnect the trackpad cable from the motherboard.
Using the JIS #00 screwdriver, remove six 2.8 mm screws securing the motherboard to the device.
Carefully grab the motherboard and lift it up slightly off of the device.
Disconnect the ZIF connector and remove the motherboard from the device.
Using the JIS #00 screwdriver, remove four 3 mm screws securing the trackpad to the device.
Using your fingers, grab the smartcard reader cable and peel it off of the device.
Еще один человек закончил это руководство.
