Введение
If your battery will no longer accept a charge and you need to replace the battery, you can do so with this guide. For this guide, you will need a T4 Torx screwdriver and a spudger. This is a popular repair and it is very easy to do!
Выберете то, что вам нужно
Gently pull the right ear pad off, starting from the top.
Slide your finger around the edges until it releases completely.
Remove the ear pad.
Remove the four screws that secure the speaker housing using a Phillips screwdriver.
Lift off the speaker housing with care not to strain the connected cable.
Gently wiggle the white battery cable connector side to side while pulling it out to disconnect the battery.
Remove the battery, using a spudger to gently pry it up if necessary.
To reassemble your device, please follow these instructions in reverse order.
5 человек успешно провели ремонт по этому руководству.
5Комментарии к руководству
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
I fully agree
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
took 2 mins to find battery info ..........................
Logi 533-000181
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
