Введение
Follow this guide to remove and replace the battery on a Logitech H800 wireless headset. You may need to do this repair if the battery no longer holds a charge.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Shift the power switch down to the OFF position to turn off the headset.
Use two fingers or your palm to rotate the battery cover on the left ear cup counterclockwise.
Tilt the left ear cup down to remove the battery cover.
Use your finger to lift up the right side of the battery about 0.5 cm (when the battery cables are oriented up).
Pull the battery to the right and away from the ear cup to remove it from the recess.
Rotate the battery 90 degrees clockwise so that it rests on the left side of the ear cup.
Use a spudger or your fingernail to pry up the edge of the battery connector resting against the flat clip enough that the whole connector pops out of the clips securing it.
Place the headset on your work surface so the control switches face up.
Place the battery on the surface so the cables face up.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech H800 Answers community for help.
2 участников успешно повторили данное руководство.
