Введение
Cables can be damaged. This guide will help when your damage your Logitech K120 keyboard’s USB cable.
Выберете то, что вам нужно
Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
Use the spudger to separate the top of keyboard from the bottom of the keyboard.
Remove the top of the keyboard and put it aside.
Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
Peel the membrane off carefully so that the membrane doesn't rip.
Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
Lift the membrane off of the first standoff.
Peel the rest of the membrane off carefully so the membrane doesn't rip.
Slide the new cable into the hole.
To reassemble your device, follow the instructions on how to reassemble your device in the prerequisite guide.
Еще один человек закончил это руководство.
4Комментарии к руководству
Hi there,
Nice guide! Where do I get hold of a replacement USB wire / what’s the specific name of it?
Thanks,
Robin
Great question. I found most of these replacement cables are on ebay or amazon as logitech mouse cable replacements.
Search the web (or Amazon) for the following:
USB Line Wire Cable Replacement Repair Logitech
hi can u send the link of cable from where u buy it
