Logitech MX Anywhere 3 for Mac Battery Replacement
Выберете то, что вам нужно
  1. Logitech MX Anywhere 3 for Mac Battery Replacement, Soften the mouse feet adhesive: шаг 1, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Soften the mouse feet adhesive: шаг 1, изображение 2 из 2
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. Logitech MX Anywhere 3 for Mac Battery Replacement, Disassembly information: шаг 2, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Disassembly information: шаг 2, изображение 2 из 2
    • There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
  3. Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the feet: шаг 3, изображение 1 из 3 Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the feet: шаг 3, изображение 2 из 3 Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the feet: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Repeat to remove the three remaining mouse feet.
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  4. Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the case screws: шаг 4, изображение 1 из 1
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the two halves of the mouse together.
  5. Logitech MX Anywhere 3 for Mac Battery Replacement, Open the mouse: шаг 5, изображение 1 из 3 Logitech MX Anywhere 3 for Mac Battery Replacement, Open the mouse: шаг 5, изображение 2 из 3 Logitech MX Anywhere 3 for Mac Battery Replacement, Open the mouse: шаг 5, изображение 3 из 3
    • Gently open the top half of the mouse up and flip it over to the right, like a book.
    • Don't try to fully remove the top shell just yet—a cable connects the upper shell to the lower case.
  6. Logitech MX Anywhere 3 for Mac Battery Replacement, Disconnect the interconnect cable: шаг 6, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Disconnect the interconnect cable: шаг 6, изображение 2 из 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  7. Logitech MX Anywhere 3 for Mac Battery Replacement: шаг 7, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement: шаг 7, изображение 2 из 2
    • Pull the cable straight out of its socket.
    • During reassembly, insert the cable with its blue tab facing up, then flip down the locking flap.
  8. Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the top half of the mouse: шаг 8, изображение 1 из 1
    • Remove the top half of the mouse.
  9. Logitech MX Anywhere 3 for Mac Battery Replacement, Reposition the wheel assembly cable: шаг 9, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Reposition the wheel assembly cable: шаг 9, изображение 2 из 2
    Купить
    • Use the point of a spudger or a pair of tweezers to pull the wheel assembly cables out from under their cable guide on the battery housing.
  10. Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the battery housing screws: шаг 10, изображение 1 из 1
    • Use a Phillips screwdriver to remove the three 3.4 mm-long screws securing the battery housing.
  11. Logitech MX Anywhere 3 for Mac Battery Replacement, Expose the battery connector: шаг 11, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Expose the battery connector: шаг 11, изображение 2 из 2
    • Don't yank or strain the battery cable.
    • Lift the battery housing up and set it aside to gain access to the battery connector underneath.
  12. Logitech MX Anywhere 3 for Mac Battery Replacement, Disconnect the battery: шаг 12, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Disconnect the battery: шаг 12, изображение 2 из 2
    • Insert each arm of a pair of pointed tweezers into the cutouts on the side of the battery connector's motherboard socket.
    • Push the connector out of its socket, just enough to grip the top of the connector with another pair of tweezers or your fingers.
    • Be careful not to let your tweezers slip out and damage the motherboard.
    • Pull the battery connector completely out of its socket to disconnect it.
  13. Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the battery housing: шаг 13, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the battery housing: шаг 13, изображение 2 из 2
    • Remove the battery housing.
  14. Logitech MX Anywhere 3 for Mac Battery Replacement, Soften the battery adhesive: шаг 14, изображение 1 из 2 Logitech MX Anywhere 3 for Mac Battery Replacement, Soften the battery adhesive: шаг 14, изображение 2 из 2
    • The battery is secured within its housing by some light adhesive.
    • Flip the battery housing over so the battery is facing down.
    • Apply a heated iOpener to the battery housing for two minutes to soften the battery adhesive.
  15. Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the battery: шаг 15, изображение 1 из 3 Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the battery: шаг 15, изображение 2 из 3 Logitech MX Anywhere 3 for Mac Battery Replacement, Remove the battery: шаг 15, изображение 3 из 3
    Tesa 61395 Tape
    $5.99
    Купить
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Insert the flat end of a spudger between the battery and its housing through one of the cutouts.
    • Pull up to peel the battery away from the adhesive.
    • Remove the battery.
    • To install a new battery:
    • Use a spudger or your fingers to peel any old adhesive off of the battery housing. The old adhesive shouldn't leave any residue.
    • If your new battery doesn't come with preinstalled adhesive, place a couple strips of double-sided tape into the battery housing.
    • Orient your new battery so its cables route through the cutout in the corner of the housing. Press the battery firmly into place to secure it.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Clay Eickemeyer
Участник с: 09/19/22
68 065 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
139 членов
Автор 17 539 руководств
2 Комментариев
Hi,
Thanks for the tuto.
Do you have a link to where I could buy the battery?
Thanks,
Louis.
Louis Garez - Ответить
Hi Louis, we checked for you and can confirm that this battery is compatible with your mouse: Logitech MX Master 3, MX Master 3S, and MX Anywhere 3 Battery - Genuine. Make sure to buy just the "Part Only" option, since we don't currently sell the rubber feet for this mouse. Keep your rubber feet intact so you can reuse them during reassembly. Good luck with your repair!
Clay Eickemeyer -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 31
За всё время: 555
