MacBook Air 11" Mid 2012 Display Assembly Replacement
Выберете то, что вам нужно
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Lower Case: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 2, изображение 1 из 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Battery: шаг 3, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement, Battery: шаг 3, изображение 2 из 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Solid-State Drive: шаг 4, изображение 1 из 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Спросите у FixBot
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 5, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 5, изображение 2 из 2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, I/O Board Cable: шаг 6, изображение 1 из 1
      • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
      Спросите у FixBot
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 7, изображение 1 из 1
      • Peel the I/O board cable up from the adhesive securing it to the fan.
      Спросите у FixBot
    3. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 8, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 8, изображение 2 из 2
      • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
      • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
      • Remove the I/O board cable.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Fan: шаг 9, изображение 1 из 1
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      Спросите у FixBot
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 10, изображение 1 из 1
      • Remove the following three screws securing the fan to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 3.6 mm T5 Torx screw
      Спросите у FixBot
    3. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 11, изображение 1 из 1
      • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Battery: шаг 12, изображение 1 из 1
      • Remove the following five screws securing the battery to the upper case:
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Спросите у FixBot
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 13, изображение 1 из 1
      • Do not touch or squeeze the six lithium polymer cells when handling the battery.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Logic Board: шаг 14, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement, Logic Board: шаг 14, изображение 2 из 2
      • Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
      • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
      Спросите у FixBot
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 15, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 15, изображение 2 из 2
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Pull the keyboard backlight ribbon cable out of its socket.
      Спросите у FixBot
    3. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 16, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 16, изображение 2 из 2
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
      • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
      Спросите у FixBot
    4. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 17, изображение 1 из 1
      • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
      Спросите у FixBot
    5. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 18, изображение 1 из 1
      • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
      • Pry up from beneath the cables.
      Спросите у FixBot
    6. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 19, изображение 1 из 3 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 19, изображение 2 из 3 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 19, изображение 3 из 3
      • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
      • Remove the small rubber gasket from the corner of the upper case near the display data cable.
      Спросите у FixBot
    7. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 20, изображение 1 из 1
      • While holding the lock away from the socket, gently pull the display data cable out of its socket.
      • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
      Спросите у FixBot
    8. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 21, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 21, изображение 2 из 2
      • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
      Спросите у FixBot
    9. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 22, изображение 1 из 1
      • Gently de-route the antenna cables from the slot cut into the logic board.
      Спросите у FixBot
    10. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 23, изображение 1 из 1
      • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
      Спросите у FixBot
    11. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 24, изображение 1 из 1
      • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
      Спросите у FixBot
    1. MacBook Air 11" Mid 2012 Display Assembly Replacement, Display Assembly: шаг 25, изображение 1 из 1
      • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
      Спросите у FixBot
    2. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 26, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 26, изображение 2 из 2
      • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the microphone ribbon cable straight out of its socket.
      Спросите у FixBot
    3. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 27, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 27, изображение 2 из 2
      • De-route the left speaker cable from the notch cut into the I/O board.
      • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
      • Pry up from beneath the wires.
      Спросите у FixBot
    4. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 28, изображение 1 из 1
      • Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
      • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
      Спросите у FixBot
    5. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 29, изображение 1 из 1
      • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
      Спросите у FixBot
    6. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 30, изображение 1 из 1
      • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
      Спросите у FixBot
    7. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 31, изображение 1 из 3 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 31, изображение 2 из 3 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 31, изображение 3 из 3
      • Peel up the six cable loops securing the antenna cables to the upper case.
      • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
      • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
      • Repeat this for all of the retaining loops.
      Спросите у FixBot
    8. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 32, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 32, изображение 2 из 2
      • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
      Спросите у FixBot
    9. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 33, изображение 1 из 1
      • Open the display until it is perpendicular to the upper case and place it on a table as shown.
      • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
      Спросите у FixBot
    10. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 34, изображение 1 из 1
      • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
      • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
      Спросите у FixBot
    11. MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 35, изображение 1 из 2 MacBook Air 11" Mid 2012 Display Assembly Replacement: шаг 35, изображение 2 из 2
      • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
      • Once the two display hinges have cleared the upper case, remove the display and set it aside.
      Спросите у FixBot
Заключение
47 человек успешно провели ремонт по этому руководству.
Andrew Optimus Goldheart
Участник с: 10/17/09
515 526 Репутация
Автор 406 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 78 419 руководств
6 Комментарии к руководству
Amazing guide, finished in under 3 hours for less than $300!
sillemleatea - Ответить Поделиться
Step 21, be careful when de-routing the wifi cables. Ensure they are Well away from the logic board when you remove it. The connectors appear to be little more than pushed onto the aerial wires and they can become EASILY separated from the cables if not fully pulled AWAY.
YOU HAVE BEEN WARNED!
Pete B - Ответить Поделиться
Yep! I was warned but managed to pull one off anyway!Why are they so impossible to put back on? I bought a replacement cable and swapped them over. Getting that bezel off was a little stressful.
But thanks A Goldberg for the guide. Invaluable.
Andy Hannen - Ответить Поделиться
Hello Andrew, congratulations for the amazing guide! Wonderful job!
I need help trying to understand what's happening with a similar model which turns on only when he wants :)
I disassembled all of it and found nothing wrong, although it still shows the same behaviour. When it turns on (rarely), it works pretty fine, but randomly reboots sometimes. I suspect that there's something wrong with the switch key inside the display part, with some faulty electrical contact. I was trying to remove the black plastic bar below the "MacBook Air" label, but it seems to break if I force it.
My questions are: How can I remove this black bar without breaking it? Is it possible instead to remove first one of the display hinges to remove the black bar by sliding it to the side? Is there any way at all to make sure that the problem is not with the switch key inside it? Unfortunatelly I don't have a spare display to test it :(
I know it can be difficult to solve, but I appreciate any help if you have!
Thanks in advance!
Marcio Tavares - Ответить Поделиться
So, I found this mac in an e-waste pile, and the display is broken. Handling 10.7 drivers, and I want to get the screen back... Although Macs are all about pretty (and I like pretty, too), if I'm not looking for pretty, and I can just put the screen on top of the broken one, can't I just unplug the data cable for the LCD, plug the new one back in and then do everything I need to do? Two screens isn't *half* as bad as one. I'm just asking to sum it up, remove data cable to screen one, attach it to another working screen, and bam? No? Yes? Plz, I really want to know. Alternatively, someone please write a guide on how to remotely make a monitor mirror a screen? That would be great! And thanks to the people that understood my subtle joke.
Revolver265 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 23
За последние 30 дней: 97
За всё время: 36,577
