MacBook Air 13” Retina Display Late 2018 Fan Replacement
Выберете то, что вам нужно
  1. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the lower case: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the battery: шаг 3, изображение 1 из 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 4, изображение 1 из 2 MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 4, изображение 2 из 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the right speaker: шаг 5, изображение 1 из 2 MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the right speaker: шаг 5, изображение 2 из 2
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
  6. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the audio board: шаг 6, изображение 1 из 2 MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the audio board: шаг 6, изображение 2 из 2
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
    • Remove the cable bracket.
  7. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 7, изображение 1 из 2 MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 7, изображение 2 из 2
    • Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
  8. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 8, изображение 1 из 2 MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
  9. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the audio board: шаг 9, изображение 1 из 1
    • Remove the following screws:
    • Two 4.3 mm, T5 Torx screws
    • One 2.4 mm, T3 Torx screw
  10. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 10, изображение 1 из 1
    • Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
  11. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 11, изображение 1 из 1
    • Remove the audio board.
  12. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the fan: шаг 12, изображение 1 из 1
    • Peel back the black tape covering the fan cable connector.
  13. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 13, изображение 1 из 3 MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 13, изображение 2 из 3 MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 13, изображение 3 из 3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  14. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Separate the audio board cable: шаг 14, изображение 1 из 3 MacBook Air 13” Retina Display Late 2018 Fan Replacement, Separate the audio board cable: шаг 14, изображение 2 из 3 MacBook Air 13” Retina Display Late 2018 Fan Replacement, Separate the audio board cable: шаг 14, изображение 3 из 3
    • Slide an opening pick under the audio board cable to slice through the adhesive securing it to the fan.
  15. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the fan: шаг 15, изображение 1 из 1
    • Use a T5 Torx driver to remove the three 2.7 mm screws securing the fan.
  16. MacBook Air 13” Retina Display Late 2018 Fan Replacement: шаг 16, изображение 1 из 1
    • Lift the fan out of the case and remove it.
Заключение
3 участников успешно повторили данное руководство.
Adam O'Camb
Участник с: 04/11/15
196 940 Репутация
Автор 416 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 32
За последние 30 дней: 190
За всё время: 4,799
