Введение
Use this guide to replace a faulty trackpad in an Early 2020 MacBook Air.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to peel back the tape covering the keyboard side of the trackpad cable on the mid board.
Use the pointed end of a spudger to lift up the small locking flap on the trackpad cable's ZIF connector.
Use a T5 Torx driver to remove the nine screws securing the trackpad:
Eight fully-coated 3.1 mm screws
One partially-coated 3.1 mm screw
While keeping the laptop screen-side down, carefully open the laptop. The trackpad will stay sitting on the display.
As you remove the trackpad assembly, be careful not to lose the five small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
Remove the trackpad.
Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
Slide the trackpad cable straight out of the ZIF connector.
3 человек успешно провели ремонт по этому руководству.
