MacBook Air 13" Late 2020 Audio Board Replacement
Выберете то, что вам нужно
  1. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: шаг 2, изображение 3 из 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: шаг 3, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: шаг 3, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: шаг 3, изображение 3 из 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  4. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board connector cover: шаг 4, изображение 1 из 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 Audio Board Replacement: шаг 5, изображение 1 из 1
    • Remove the audio board connector cover.
  6. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: шаг 6, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: шаг 6, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: шаг 6, изображение 3 из 3
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
  7. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: шаг 7, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: шаг 7, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: шаг 7, изображение 3 из 3
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
  8. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: шаг 8, изображение 1 из 2 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board screws: шаг 9, изображение 1 из 1
    • Remove the three screws securing the audio board:
    • Two 4.8 mm T5 Torx screws
    • One 2.5 mm T3 Torx screw
  10. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: шаг 10, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: шаг 10, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: шаг 10, изображение 3 из 3
    • Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
    • Remove the audio board.
Заключение
Once you've completed your repair, your laptop may not power back on until connected to power.
8 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
113 910 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 166 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 82
За последние 30 дней: 367
За всё время: 8,059
