MacBook Air 13" Late 2020 Lower Case Replacement
Выберете то, что вам нужно
  1. MacBook Air 13" Late 2020 Lower Case Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    Спросите у FixBot
    Добавить комментарий
  2. MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: шаг 2, изображение 3 из 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
166 720 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
122 членов
Автор 27 491 руководств
1 Комментарий к руководству
Hi, I accidentally stripped one of the female thread in the chassis what can I do to fix this? as the screw won't stay in place/screw in
TheTechDisassembler24 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 79
За последние 30 дней: 399
За всё время: 31,177
