MacBook Air 13" Late 2020 Microphone Array Replacement
Выберете то, что вам нужно
  1. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the lower case: шаг 2, изображение 3 из 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the battery: шаг 3, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the battery: шаг 3, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the battery: шаг 3, изображение 3 из 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  4. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the audio board connector cover: шаг 4, изображение 1 из 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 5, изображение 1 из 1
    • Remove the audio board connector cover.
  6. MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the right speaker connector: шаг 6, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the right speaker connector: шаг 6, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the right speaker connector: шаг 6, изображение 3 из 3
    • The right speaker will be on your lefthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
  7. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the right speaker screw: шаг 7, изображение 1 из 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
  8. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: шаг 8, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: шаг 8, изображение 2 из 2
    • Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
  9. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 9, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 9, изображение 2 из 2
    • Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Pull the adhesive strip until it's freed from under the speaker.
    • If the adhesive strip breaks, use a heated iOpener, a heat gun, or a hair dryer to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  10. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the right speaker: шаг 10, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the right speaker: шаг 10, изображение 2 из 2
    Tesa 61395 Tape
    $5.99
    Купить
    • Remove the right speaker.
    • During reassembly, to ensure the speaker performs as expected, install a strip of replacement adhesive on its underside before placing it back into the case.
  11. MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the left speaker connector: шаг 11, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the left speaker connector: шаг 11, изображение 2 из 2
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
  12. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the left speaker screw: шаг 12, изображение 1 из 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
  13. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: шаг 13, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: шаг 13, изображение 2 из 2
  14. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 14, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 14, изображение 2 из 2
  15. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the left speaker: шаг 15, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the left speaker: шаг 15, изображение 2 из 2
    Tesa 61395 Tape
    $5.99
    Купить
    • Remove the left speaker.
  16. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the trackpad cable cover: шаг 16, изображение 1 из 1
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
  17. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 17, изображение 1 из 1
    • Remove the trackpad cable cover.
  18. MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the trackpad cable: шаг 18, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the trackpad cable: шаг 18, изображение 2 из 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  19. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 19, изображение 1 из 1
    • Carefully peel the trackpad cable off of the battery.
    • The trackpad cable is secured to the battery with some light adhesive.
  20. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the battery tray screws: шаг 20, изображение 1 из 1
    • Use a T3 Torx driver to remove the two 2.6 mm screws securing the battery tray to the case.
  21. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the battery tray adhesive strips: шаг 21, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the battery tray adhesive strips: шаг 21, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the battery tray adhesive strips: шаг 21, изображение 3 из 3
    • The MacBook's battery cells are attached to a metal tray as a complete assembly, which is adhered to the case with a total of six stretch-release adhesive strips.
    • Don't attempt to remove the battery cells from their metal backing tray.
    • On the left side of the MacBook, use a pair of tweezers to peel back the three black pull tabs on the battery's stretch-release adhesive strips until you can grip them with your fingers.
  22. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 22, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 22, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 22, изображение 3 из 3
    • Grab an adhesive strip's pull tab and slowly pull it out from underneath the battery.
    • Pull the adhesive strip until it's freed from under the battery.
    • Repeat for the two remaining adhesive strips on the battery's left side.
  23. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 23, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 23, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 23, изображение 3 из 3
    Plastic Cards
    $2.99
    Купить
    • Repeat and remove the three adhesive strips from the right side of the battery.
    • If any of the six adhesive strips broke during removal, you can use a plastic card to finish separating the battery tray from the case.
  24. MacBook Air 13" Late 2020 Microphone Array Replacement, Remove the battery: шаг 24, изображение 1 из 1
    • Remove the battery assembly.
    • If you're installing a new battery, follow the calibration procedure:
    • Charge it to 100%, and keep charging it for at least 2 more hours.
    • Unplug and use it normally to drain the battery.
    • When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery.
    • Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  25. MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the microphone cable: шаг 25, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement, Disconnect the microphone cable: шаг 25, изображение 2 из 2
    • Use a pair of tweezers to peel back the tape covering the microphone cable connector.
  26. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 26, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 26, изображение 2 из 2
    • Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
  27. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 27, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 27, изображение 2 из 2
    • Slide the microphone cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  28. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 28, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 28, изображение 2 из 2
    • Slide an opening pick underneath the microphone cable to separate it from the upper case.
    • The cable is secured with some light adhesive.
    • If the adhesive is stubborn, don't force the pick. Lightly heat the microphone assembly using an iOpener or a hair dryer to soften the adhesive.
  29. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 29, изображение 1 из 2 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 29, изображение 2 из 2
    • Slide an opening pick underneath the microphone closest to the center of the MacBook to slice through the adhesive securing it to the upper case.
    • Lift up to pry the microphone out of its recess in the case.
  30. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 30, изображение 1 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 30, изображение 2 из 3 MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 30, изображение 3 из 3
    • Use the pointed end of a spudger to carefully pry one of the remaining microphones out of its recess in the upper case.
    • If the adhesive is stubborn, apply heat to the microphone to soften the adhesive.
    • Don't force the spudger under the microphone or you risk ripping the cable.
    • Remove the third and final microphone from the case.
  31. MacBook Air 13" Late 2020 Microphone Array Replacement: шаг 31, изображение 1 из 1
    • Remove the microphone array.
Заключение
Once you've completed your repair, your laptop may not power back on until connected to power.
4 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
113 709 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 49
За последние 30 дней: 198
За всё время: 4,657
