MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 3, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 3, изображение 2 из 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Battery Connector: шаг 4, изображение 1 из 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 5, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 5, изображение 2 из 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 6, изображение 1 из 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Right Speaker: шаг 7, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Right Speaker: шаг 7, изображение 2 из 2
    • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
    • Remove the I/O board cable bracket.
  8. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 8, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  9. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 9, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 9, изображение 2 из 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  10. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 10, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 10, изображение 2 из 2
    • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
  11. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 11, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 11, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 11, изображение 3 из 3
    • Carefully peel the right speaker cable off the upper case.
  12. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 12, изображение 1 из 1
    • Remove the following screws securing the right speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  13. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 13, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 13, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 13, изображение 3 из 3
    • Lift the right speaker from the cable end and pull it free from the case.
  14. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Left Speaker: шаг 14, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Left Speaker: шаг 14, изображение 2 из 2
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
    • Be careful not to damage any surface-mounted components.
  15. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 15, изображение 1 из 1
    • Remove the following screws securing the left speaker to the upper case:
  16. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 16, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 16, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 16, изображение 3 из 3
    • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
  17. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Trackpad Cable: шаг 17, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Trackpad Cable: шаг 17, изображение 2 из 2
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
  18. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 18, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 18, изображение 2 из 2
    • Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
    • Be careful not to damage the cable. If it doesn't peel up easily, apply a little heat from an iOpener, heat gun, or hair dryer to soften the adhesive, and try again.
    • If you are installing a new trackpad cable, be sure to fold the new cable to match the shape of the old cable. The new cable will appear to be too long if it is not folded.
  19. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 19, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 19, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 19, изображение 3 из 3
    • If necessary, peel back any tape covering the trackpad cable connector.
    • Use the end of a spudger to flip the retaining tab on the ZIF connector.
  20. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 20, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 20, изображение 2 из 2
    • Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
    • During reassembly, make sure that the retaining tab is in the up, "unlocked" position before you insert the cable into the socket.
  21. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 21, изображение 1 из 1
    • Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
  22. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Battery: шаг 22, изображение 1 из 1
    • The liquid adhesive remover provided in your iFixit battery replacement kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  23. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 23, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 23, изображение 2 из 2
    • If you have an iFixit battery kit with liquid adhesive remover, it's time to get it prepped.
    • Alternatively, if you are using the hot iOpener method, skip the following three steps.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  24. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 24, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 24, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 24, изображение 3 из 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  25. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 25, изображение 1 из 1
    • Apply a few drops of adhesive remover evenly under the edge of the rightmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  26. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 26, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 26, изображение 2 из 2
    • If you don't have a liquid adhesive remover, you'll be using a hot iOpener to warm and soften a section of the adhesive securing the battery to the upper case, and then carefully prying at that point.
    • Use the hot iOpener to cover half of the right-most battery cells.
    • After about a minute, reheat the iOpener and move it to cover the other half of the right-most battery cells.
  27. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 27, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 27, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 27, изображение 3 из 3
    Plastic Cards
    $2.99
    • Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two.
    • Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    • When using the hot iOpener method, if you encounter significant resistance to prying, stop and use the iOpener to reheat the section you're working on.
  28. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 28, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 28, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 28, изображение 3 из 3
    • Repeat this procedure with the adjacent battery cell:
    • Apply a small amount of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Alternatively, re-heat this section with your iOpener if needed.
    • Push a plastic card about an inch between the battery cell and the upper case, and slowly pry the cell up to separate all of the adhesive.
  29. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 29, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 29, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 29, изображение 3 из 3
    • Temporarily leave your plastic card underneath the two rightmost battery cells to prevent them from re-adhering to the upper case.
    • If using an iOpener, reheat it and reapply it, this time to the left-most battery cells.
    • Again, leave the iOpener in each position for about a minute, reheating in between, to heat each half of the left-most battery cells.
  30. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 30, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 30, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 30, изображение 3 из 3
    • Repeat the above procedure to separate the two leftmost battery cells from the upper case.
    • Remember to apply a small amount of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Use a second plastic card to separate the two leftmost battery cells from the upper case.
  31. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 31, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 31, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 31, изображение 3 из 3
    • Continue to repeat the prying procedure.
    • Insert the plastic card between the second left-most battery cell and the upper case to cut the adhesive joining the two, and pry the cell up from the case.
  32. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 32, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 32, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 32, изображение 3 из 3
    • Leave the second card in the corner between the two left cells.
    • If using an iOpener, reheat it and apply it to the central battery cells.
    • As before, leave the iOpener in each position for about a minute, reheating in between, to heat each half of the center cells.
    • In the following steps, you can either use a third card, or the card from the right corner. The right corner adhesive should be dry/cool enough that the cells can easily be pulled up again when needed.
  33. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 33, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 33, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 33, изображение 3 из 3
    • If using liquid adhesive remover, apply a few more drops under each of the final two, middle cells.
    • It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
    • Allow 2-3 minutes for the adhesive remover to penetrate before you continue.
    • Gently folding the right-most battery cells out of the way, insert a plastic card under the right center cell.
    • Push the card in about half of its length to cut the adhesive holding the battery cell to the case.
    • Be sure to avoid the trackpad control board. Aim the card up toward the logic board, where the adhesive is.
    • Leave the card in place to keep the adhesive from re-sealing.
  34. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 34, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 34, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 34, изображение 3 из 3
    • Repeat the same procedure for the last remaining battery cell.
    • Holding the outer cells out of the way, insert the plastic card about halfway under the left center battery cell, avoiding the trackpad board.
  35. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 35, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 35, изображение 2 из 2
    • Return to the card beneath the right-center cell, and twist it to separate the entire battery from the upper case.
    • By now you should have cut all of the adhesive securing the battery to the upper case, and it should come out freely.
    • If it does not come out easily, you may need to reheat the iOpener and apply it to the stuck areas, and then continue gently cutting the adhesive with the plastic cards.
  36. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 36, изображение 1 из 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 36, изображение 2 из 2
    • Remove the battery.
    • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them last.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
  37. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement, Trackpad: шаг 37, изображение 1 из 1
    • Remove the ten 2.8 mm T3 screws securing the trackpad cover plate to the upper case.
  38. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 38, изображение 1 из 1
    • Remove the trackpad cover plate.
  39. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 39, изображение 1 из 1
    • Remove the twelve 2.4 mm T5 screws securing the trackpad to the upper case.
  40. MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 40, изображение 1 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 40, изображение 2 из 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement: шаг 40, изображение 3 из 3
    • Lift up and remove the trackpad from the upper case.
Заключение
77 человек успешно провели ремонт по этому руководству.
Andrew Optimus Goldheart
Участник с: 10/17/09
514 567 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
125 членов
Автор 25 376 руководств
33 Комментарии к руководству
Is there a way to get a calibration software somehow ? Is Apple offering paid calibration service and what is the cost?
Windcatcher - Ответить Поделиться
I just followed this repair guide. NO calibration whatsoever needed. It worked like a charm (like new) once I assembled everything back together.
No software needed
David Chin - Поделиться
If you do this yourself, Apple will not touch your laptop with a 10-foot pole, you will have voided any existing warranty. They would require you to purchase a new trackpad from them and they will install/calibrate it themselves
MacAmbulance - Ответить Поделиться
Can you only replace the control board of the trackpad ?
Gilliano - Ответить Поделиться
I don’t think they sell the control board separate from the trackpad panel - comes soldered together
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 16
За последние 7 дней: 134
За последние 30 дней: 558
За всё время: 186,295
