MacBook Pro 13" Unibody Late 2011 Logic Board Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 2, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 2, изображение 2 из 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Battery Connection: шаг 3, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Battery Connection: шаг 3, изображение 2 из 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 4, изображение 1 из 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Fan: шаг 5, изображение 1 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Fan: шаг 5, изображение 2 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Fan: шаг 5, изображение 3 из 3
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 6, изображение 1 из 1
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 7, изображение 1 из 1
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
  8. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Logic Board: шаг 8, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Logic Board: шаг 8, изображение 2 из 2
    • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
    • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
  9. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 9, изображение 1 из 1
    • Disconnect the camera cable from the logic board.
    • The camera cable lifts straight away from the logic board. If your cable feels fragile, use a spudger to pry up on the small metal tabs on each side of the connector head to disconnect the cable.
  10. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 10, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 10, изображение 2 из 2
    • Disconnect the following four cables:
    • AirPort/Bluetooth cable
    • Optical drive cable
    • Hard drive cable
    • Trackpad cable
    • To disconnect the cables, use the flat end of a spudger to pry their connectors up from the sockets on the logic board.
  11. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 11, изображение 1 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 11, изображение 2 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 11, изображение 3 из 3
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
  12. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 12, изображение 1 из 1
    • If present, remove the small strip of black tape covering the keyboard backlight cable socket.
  13. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 13, изображение 1 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 13, изображение 2 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 13, изображение 3 из 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  14. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 14, изображение 1 из 1
    • Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
  15. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 15, изображение 1 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 15, изображение 2 из 3 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 15, изображение 3 из 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  16. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 16, изображение 1 из 1
    • Remove the following nine screws:
    • Five 3.6 mm T6 Torx screws
    • Two 4.3 mm T6 Torx screws
    • Two 7.2 mm T6 Torx screws
    • In some models the screws may be slightly shorter as follows:
    • Five 3.0 mm T6 screws
    • Two 3.6 mm T6 screws
    • Two 6.7 mm T6 screws
  17. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 17, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 17, изображение 2 из 2
    • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
    • Remove the display data cable retainer from the upper case.
  18. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 18, изображение 1 из 1
    • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
  19. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 19, изображение 1 из 1
    • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
    • Remove the logic board.
  20. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Left Speaker: шаг 20, изображение 1 из 1
    • De-route the microphone cable from its slot molded into the left speaker enclosure.
  21. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 21, изображение 1 из 1
    • Remove the small piece of black tape covering the left speaker connector.
  22. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 22, изображение 1 из 1
    • Use the flat end of a spudger to pry the left speaker connector up from its socket on the logic board.
    • Pry up from beneath the wires.
  23. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 23, изображение 1 из 1
    • Carefully pry the left speaker off the foam adhesive securing it to the logic board.
    • Remove the left speaker.
  24. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement, Logic Board: шаг 24, изображение 1 из 1
    • Remove the piece of black tape covering the microphone connector.
  25. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 25, изображение 1 из 1
    • Pull the microphone cable upward to lift its connector out of the socket on the logic board.
    • Remove the microphone.
  26. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 26, изображение 1 из 1
    • Pull the MagSafe DC-In board cable toward the heat sink to disconnect it from the logic board.
    • Remove the DC-In board.
  27. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 27, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 27, изображение 2 из 2
    • Remove the three 8.4 mm #1 Phillips screws securing the heat sink to the logic board.
    • Don't lose the springs held under each of the screws.
    • Carefully remove the heat sink from the processor.
    • If the heat sink seems to be stuck, it may be helpful to gently pry it off the processor with a plastic spudger. Be careful not to break any surface mount components on the processor while prying.
    • Be sure to clean off the old thermal paste and apply a new layer before you reinstall the heat sink. We have a guide that makes it easy.
  28. MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 28, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Logic Board Replacement: шаг 28, изображение 2 из 2
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should "pop" up slightly from its socket.
    • Pull the RAM stick out of its socket.
    • Repeat this process to remove the second RAM chip.
    • Logic board remains.
Заключение
100 участников успешно повторили данное руководство.
Phillip Takahashi
Участник с: 08/22/11
86 704 Репутация
Автор 87 руководств
5 Комментариев
Great Guide thank you Phillip for providing it here. I could not have brought my MacBook Pro back to life without it! I used it to swap logic boards from a case damaged, but working MC724 into a water damaged MD313 with a pristine case.
fasthans - Ответить
Hello guys,
I have a question for you : if i need to change my macbook pro early 2011 logic board (the one with the core i5 2.3ghz) with a late 2011 logic board (core i5 2.8Ghz). will it work ? thanks a ton for any input on that matter !
guillaume polizzi - Ответить
Should be fine Guillaume, things to note are: The serial number will give the old info of the old main board. Also the CPU cooler my be different, on 1 I noticed the cooler has 2 fans on the 2.3Mhz it has 1. Assuming you have both cases in front of you, I don't see to much of an issue.
I would advise taking the memory out sooner then the last step, as while your trying to maneuver everything around it seems the sticks could get in one's way or even worse break off the retaining tabs for the memory.
Philip settimi - Ответить
Hey guys, I changed my logic board but now I’m not getting any audio. The headphones nor the speakers seems to be working. Can anyone assist me or suggest what can be done to fix this?
felil_boss101 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 54
За последние 30 дней: 174
За всё время: 88,951
