Введение
Use this guide to safely remove the glued-in battery from your MacBook Pro with the help of an iFixit kit with adhesive remover. The adhesive remover is designed to weaken the glue securing the battery, allowing you to remove it with ease.
iFixit adhesive remover is flammable. Follow this procedure in a well-ventilated area. Do not smoke or work near an open flame.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Note: The solvent used to dissolve the battery adhesive can damage certain plastics. Follow all instructions and take care where you apply the adhesive remover.
Выберете то, что вам нужно
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Close the display and flip the entire laptop upside-down.
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 4.7 mm screws
Two 6.6 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Lift up on the suction handle just enough to open a small gap under the lower case.
Slide the corner of an opening pick into the gap you just created underneath the lower case.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the opposite side, using your opening pick to release the second clip.
Lift the front edge of the lower case (the side opposite the display hinge) just enough to slide your fingertips underneath and get a good grip on it.
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips. You should feel and hear them click into place.
Peel up and remove the large rectangular battery board cover, on the edge of the logic board nearest the battery.
If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Disconnect the battery board data cable by sliding it out from its socket.
Slide parallel to the logic board, in the direction of the cable.
Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Use a T3 Torx driver to remove the two 1.9 mm screws securing the trackpad cable's cover bracket.
Remove the bracket.
Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
Carefully peel the trackpad cable up off the battery, and push it out of the way.
Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
Nine 5.8 mm screws
Four 4.9 mm screws
Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
Gently feed the trackpad's ribbon cable through its slot in the chassis.
As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
Remove the trackpad assembly.
Using a T3 Torx driver, remove the two 1.9 mm screws securing the keyboard connector cover bracket.
Remove the bracket.
Use your spudger to disconnect the keyboard by prying its connector straight up from the logic board.
Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
Remove the display board flex cable cover.
Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
Remove the bracket from the display board cable connector.
Use a T3 Torx driver to remove the two 2.0 mm screws securing each hinge cover (four screws total).
Use a T3 Torx driver to remove the two 2.4 mm screws securing the cover bracket for the Touch ID and headphone jack cable connectors.
Remove the bracket.
Disconnect the headphone jack cable by prying its connector straight up from the logic board.
Disconnect the power button and Touch ID sensor by prying its connector straight up from the logic board.
Use a T3 Torx driver to remove the 1.3 mm screw securing the cover bracket for the Touch Bar digitizer connector.
Using your tweezers, slide the bracket toward the side edge of the MacBook Pro until it clears the slotted retaining tab on the logic board.
Remove the bracket.
Disconnect the Touch Bar digitizer cable by prying it straight up from the logic board.
Use a T3 Torx driver to remove the two 1.9 mm screws securing the bracket for the Touch Bar display cable connector.
Remove the bracket.
Disconnect the Touch Bar display cable by prying its connector straight up from the logic board.
Use a T3 Torx driver to remove the four 1.3 mm screws securing the Thunderbolt flex cable covers:
Two screws on the left
Two more on the right
Disconnect the left-side Thunderbolt flex cable by prying it straight up from the logic board.
Pry from the inside edge, nearest the fan.
Gently push the flex cable connector off to the side so it doesn't interfere with logic board removal.
Repeat to disconnect the Thunderbolt flex cable connector on the opposite side.
Carefully push the flex cable connector aside so there's clearance for the logic board to come out without snagging.
Disconnect the two speaker connectors by sliding the flat end of your spudger underneath each cable near its connector.
Gently twist or pry up to disconnect both speakers.
Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
Disconnect the microphone by pulling its cable toward the fan until it releases from its socket.
If possible, pull on the tape attached to the cable, rather than the cable itself, to reduce the risk of damage.
Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
Disconnect all three antenna cables by prying each one straight up from its socket.
Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
Remove the ten screws securing the logic board assembly:
Two 2.8 mm T3 Torx screws
Five 2.9 mm T5 Torx screws
One 3.7 mm T5 Torx screw
One 3.9 mm T8 Torx screw
One 3.8 mm T8 Torx screw
Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans.
If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
Check the alignment of the rubber vibration dampers, and adjust them as needed.
Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
Verify that no cables get trapped under the board as you install it. Check each marked location carefully.
Remove the two screws securing the battery board:
2016-2017 models: Use a T5 Torx driver to remove both 3.5 mm screws.
2018-2019 models: Use a P2 Pentalobe driver to remove both 3.2 mm screws.
To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
Additionally, use painter's tape to seal off the area under the trackpad as best you can. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
To control the flow of adhesive remover, raise the back edge (hinge side) of your MacBook Pro a few inches using a book or foam block.
Now that your MacBook Pro is fully prepped, it's time to prep yourself.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
Pull off the black rubber stopper from your bottle of adhesive remover.
Use scissors to cut off the sealed tip of the applicator.
Apply a few drops of adhesive remover underneath the two battery cells on the right, starting along the edge nearest the fan.
Add a few more drops of adhesive remover in between the two battery cells on the right, so that it flows down underneath the lower battery cell.
Wait about two minutes for the liquid adhesive remover to penetrate and weaken the battery adhesive before you proceed to the next step.
After a couple minutes, insert one corner of a plastic card underneath the battery, starting from the lower edge of the bottom, right-most cell.
Wiggle the card from side to side and slide it all the way underneath both battery cells.
Lift the cells to fully separate the adhesive, but don't try to remove them from your MacBook yet.
Leave the plastic card temporarily underneath the cells to prevent the adhesive from re-bonding as you proceed to the next step.
Switch to the left side of the MacBook Pro, and repeat the previous step to separate two more battery cells.
Leave the second plastic card in place temporarily.
Apply a few drops of adhesive remover along the top edges of the two center battery cells.
Be mindful of leaks, and apply more adhesive remover along the side edges if needed.
After a couple minutes, retrieve your first plastic card and insert one corner under the top edge of one of the center battery cells.
Wiggle it from side to side and slide it underneath the battery cell until all the adhesive separates.
Retrieve your second plastic card and repeat the previous step to separate the remaining center battery cell.
If you had trouble getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
Lift and remove the battery.
Peel off any large strips of adhesive using tweezers or gloved fingers.
Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
Carefully position the battery and set it into place.
Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
After your battery is properly positioned and installed, peel off and discard the clear plastic liner from the top.
Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
121 участников успешно повторили данное руководство.
52 Комментариев
it’s an unbelievably undesired design that glues everything together. And the design arrangement for the screen was just… annoying.
Holy &&^&^$^ $@$*, good thing you dont have to delaminate the screen just to replace the battery. Wtf.
Why removing the logic board. I don’t understand it seems useless. Just detach the battery cables and the battery.
There is a video on youtube that shows this (think its turkish, and they only disconnect the battery and start removing it from there with a plastic spatuala). I think its more to do with the fact that this guide doesnt want accidental spillage of adhesive remover onto the logic board. Also to avoid and damage to the board when cleaning the remenants.
